Why Does the Moment of Inertia of a Rod Equal ML^2/12?
pchalla90
Show that the rotational inertia of the rod about an axis through its center and perpendicular to its length is ML^2/12, where M is Mass and L is length from axis of rotation.
∫r^2dm=Mr^2
Well, you see the integral that I did in the relevant equations? I got most of the work done there, assuming that R=L. My problem is understanding where the /12 comes from in the question. There were no numbers given in the initial question, just M and L.
Great. dm should have a dr in it. What's R? What are the limits on your integral? Take rho to be the density of the rod per unit length. What's M in terms of rho and L? What's the moment of inertia in terms of rho and L? Now eliminate rho.
well, dm=pdL is what I am assuming...
so ∫dm=∫pdL
M=pL
but shouldn't the right side of the above equation be a definite integral while the left is an indefinite integral?
i think the right side of the above equation should go from -L/2 to L/2, but that raises the question of the limits of the left side of the equation...
either way, assuming both sides are indefinite integrals, substituting pL for M in ML^2 gives me
pL^3=I
but that's as much as i think i understood of your post.
thanks for the quick reply.
Now you want to integrate r^2*rho*dr for r from -L/2 to +L/2 to get the moment of inertia. Then use M=rho*L to get rid of the rho.
Okay, so...
∫(-L/2,L/2) pR^2dr= (1/3)R^3p|(-L/2,L/2)
=(1/3)(L/2)^3p-(1/3)(-L/2)^3p
=(1/3)(L/2)^3p+(1/3)(L/2)^3p
=(2/3)(L^3/8)p
=L^3/12p
p=M/L
=(L^3/12)(M/L)
=ML^2/12
Thank you so much for your help.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
