Which soup can would hit the bottom of an inclined plane first?
  • Thread starter Thread starter cherica48
    Moment
When comparing two soup cans on an inclined plane—one empty and one filled with soup—the filled can is expected to reach the bottom first. This is due to the differences in moment of inertia, where the liquid-filled can has its mass more centered, reducing resistance to motion. The discussion references the solid disk and hollow ring analogy to illustrate how mass distribution affects inertia. The empty can, having a higher moment of inertia, will roll less efficiently down the incline. Understanding these principles clarifies why the liquid-filled can is likely to win the race.
cherica48
This is probably a very very lame question, as it's probably a very basic concept, but I have been quite ill and missed wednesday through monday's physics lessons. Basically, if I have 2 soup cans- one empty, one with soup in it, and set them on an inclined plane, which will hit the bottom first?
My initial interpretation of moment of inertia seems to be that I'm looking for the object that will most resist motion. If it were a solid base inside a can going against a liquid soup can, then I'd say the liquid one would win, as it would not have to roll it's mass along with the can, as a solid base would. However, in this case, though I don't have a way to explain why, my guess would still be in favor of the liquid-filled can, perhaps because the mass is more centered in its case? Sorry, my head is really fogged up here. I'd love to hear that this theory is correct, but if not I'd also love to hear an explanation that I can make sense of. Thanks!
To help you out, take the solid disk and hollow ring example. A hollow ring's general moment of inertia equation is I=mr^2 and the disk's equation is I=\frac{1}{2}mr^2. By looking at these equations, you can tell which one has the greater moment of inertia. Think about why a hollow ring has more moment of inertia than does a solid ring (also called a disk). Think about the location of the object's mass from its center.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
