Understanding Moments of Inertia & Tensors
In summary, the moment of inertia is a concept used in physics to represent the mass distribution of a rotating body about an axis. It can be calculated using the formula (dm)r2, where dm is the mass of a small element and r is the distance from the axis. The concept of a tensor, specifically a second rank tensor, is also related to the moment of inertia and is used to represent the rotational kinetic energy of a body. The inertia tensor originates from the study of rigid systems and extends the concept of mass to rotating systems. The parallel axis theorem is a useful tool for calculating the moment of inertia for 3-dimensional bodies.
enigma
Staff Emeritus
This may be a sort of odd question.
I know what a moment of inertia is. I know what they represent, I know how to use them, I even know how to calculate them from scratch if need be.
But I don't know why they are what they are.
Why is it that this weird value with seemingly random d^2 terms provides the mass distribution about an axis?
Probably more to the point:
What, conceptually, is a tensor?
Mathematics news on Phys.org
The definition from which you calculate them from scratch tells you a lot. The moment of inertia about an axis due to a point mass is (dm)r2. Those factors for different shapes arise out of the simple adding up of all the point contributions.
A second rank tensor (which the moment of inertia is) is, for these purposes, that which can be represented as a square matrix (3x3, in this case). It needs to be 3x3 so that it can be contracted with two 3-vectors, as in the expression for rotational kinetic energy, like so:
K=(1/2)ωTIω
where ω is a column vector representing the angular velocity and ωT is its transpose.
But why r^2 (other than to get the units to come out right...)
Again, this is a stupid -mybraincan'tcomprehendsomethingentirelyunlessIgetitentirely- type question.
I know what it does, I just don't know why it does what it does.
Okay well here goes an attempt to explain it:
  • So let's start with what we know. Torque by definition is force times the lever arm (or rxF to be more precise about it). This definition makes sense so we will start from here.
  • Given this definition of torque we can say that Στ = (ΣF)r. Here we'll assume, (just becuase I don't know how to do so otherwise) that all the forces are acting at the same distance and are acting perpindicularly.
  • Okay but the second term looks familiar to us. Newtons law ΣF = ma, so we'll substitute and get Στ = mar.
  • But now were dealing with rotations not linear motion so we'll remember that a = αr. So substituting again we find Στ = mαrr. Simplifying we get Στ = mr2α.
  • Since we know in rotations that Στ = Iα it follows that from above I = mr2.
Okay I know that's a little presumptious but does it help at all? I'll see if I can't find a better way.
AHA
THATS what I needed.
Thanks climbhi!
Oh, I thought you wanted to know why the coefficients to (mr2) were all different!
Very nice, climbhi.
Thanks, I'm glad that helped. So Tom do you have any ideas on how you could tweak with what I had above so that you don't have to make that assumption that I made. In other words can you generalize it to a system of n particles where the forces aren't neccesarily acting perpindicularly on these particle and get the result to come out I = ∫r2dm?
I'll do the first one now (nonperpendicular forces), and the second one tomorrow (continuum of mass).
Here's the "vector version":
Στ=ΣFxr
Στ=Σmaxr
Στ=Σmrαxr
Now note that rr=r2r,
where the italicized vector is the unit vector in the radial direction. So...
Στ=Σmr2αxr
That the product αxr gives the right direction is left as an exercise for the reader.
(That means I got to run!)
No argument with your approach to tensors, Tom. For my (engineering) students, I write:
A scalar has magnitude and no direction
A vector has magnitude and one direction
A (2nd order) tensor has magnitude and two directions
(one for the traction vector and one for the plane of action)
then:
scalar = 0th order tensor has 3^0 components (in 3-space)
vector = 1st order tensor has 3^1 components
2nd order tensor has 3^2 components
and so on to higher order tensors.
A (2nd order) tensor is then a kind of supervector.
Thoughts?
Ron.
Can't the form for the moment of inertia be derived from conservation laws?
Probably, I remember deriving it from first principles in my physics class but when i went back to check my notes I couldn't find it. I think we started by throwing a whole series of dots on the board and looking at what happens on each particle and then applying it to the whole system. I can't remember how to do it though. Anyone want to take a stab at it?
aXr doesn't give the right direction
its
rXa
The parallel axis theorem helps to extend calculating the moment of inertia to arbitrary 3-dimensional bodies.
Yes, parallel axis theorem = most convenient thing ever!
The inertia tensor originates from the study of (discrete or continuous) rigid systems, which are systems that preserve relative distances among their parts.
The inertia tensor does not involve any dynamical consideration (forces and torques) in its definition. It is simply a powerful tool to calculate both kinetic energy and angular momentum of a rigid system.
This tensor extends the concept of mass to rotating systems; mass determines how much speed you will gain when you transfer a certain (linear) momentum, inertia tensor determines what angular speed you will attain by trasfering a certain angular momentum:
p=mv
L=Iw
(Consider anyway that angular momentum depends on a prefixed pole and so will the inertia tensor; the problem can be simplified by breaking the motion into two parts one relative to the the center of mass the other treating the whole system as concentrated in the center of mass)
What characterizes a (3D real symmetric) tensor is that there are three direction of space mutually orthogonal that make the tensor diagonal. Hence a (3D real symmetric) tensor can always be thought as the rotation of these diagonal tensor. The way the diagonal tensor acts on the components of a vector is really simple since it simply multiplies each of the components for a simple number. The three numbers (principal inertia moments in our case) usually differ from each other; a scalar multiplying a vector can be simply thought as a tensor with three identical principal components.
To go back to the comparison with mass and velocity/momentum, there are conditions in which the (effective) mass will be different dipending on the direction of momentum (e.g. in many crystals) and these can be represented by an (effective) mass tensor. The same happens with many physical objects usually considered as scalars such as conductivity, index of refraction, etc.
The simplest way to see how each component contributes to the inertia tensor is by using a system constituted by a single mass rotating around a prefixed axis with (variable) angular velocity ω
Let us consider the origin as the pole for momentum calculation and a rotation axis passing through the origin/pole
L=OPxmv=OPxm(ωxOP)=m(|OP|^2-OPOP)ω=Iω
Now if you want to extend the concept to a system of masses you need to have a system in which the velocity of each mass point can be written as a vector product of the SAME angular velocity and position.
In general this is possible for rigid systems only after separating the contribution of the center of mass.
Mathworld link for angular momentum (http://scienceworld.wolfram.com/physics/AngularMomentum.html) could help but beware that it is full of little mistakes and it does not even mention that its calculation of the inertia tensor works only for rigid systems.
Hope this helps, Dario
FAQ: Understanding Moments of Inertia & Tensors
What is moment of inertia?
Moment of inertia is a measure of an object's resistance to changes in its rotational motion. It is also known as angular mass and is dependent on an object's mass, shape, and distribution of mass.
How is moment of inertia calculated?
Moment of inertia is calculated by multiplying the mass of an object by the square of its distance from the axis of rotation. This value is also affected by the shape and distribution of mass of the object.
What is a tensor?
A tensor is a mathematical object that represents the relationship between different coordinate systems. In the context of moments of inertia, tensors are used to describe the orientation and distribution of mass of an object in three-dimensional space.
How does understanding moments of inertia help in real-life applications?
Understanding moments of inertia is crucial in many real-life applications, such as engineering and physics. It helps in predicting an object's rotational motion, stability, and response to external forces. This knowledge is essential in designing structures, vehicles, and machines that can withstand various forces and function properly.
What are some common misconceptions about moments of inertia?
One common misconception about moments of inertia is that it is only relevant for objects rotating about a fixed axis. In reality, moments of inertia can also be calculated for objects rotating about different axes or for irregularly shaped objects. Another misconception is that moments of inertia are solely dependent on an object's mass. As mentioned earlier, an object's shape and distribution of mass also play a significant role in determining its moment of inertia.
