Momentum and Elastic Collisions: Finding Final Velocity Ratio
  • Thread starter Thread starter fizics
    Momentum
The discussion centers on calculating the final velocity ratio (v_f/v_0) in a scenario involving a massless elastic cord and two colliding objects with masses 3m and m. The problem specifies that the collision is perfectly elastic and occurs on a frictionless surface. The correct approach to find the final velocity ratio is rooted in the conservation of momentum, leading to the conclusion that v_f/v_0 equals 1/sqrt(2), although one participant initially miscalculated this ratio.
  • Understanding of Hooke’s Law and elastic collisions
  • Knowledge of conservation of momentum principles
  • Familiarity with one-dimensional motion in physics
  • Basic algebra for solving equations
  • Study the principles of elastic collisions in detail
  • Learn about Hooke’s Law and its applications in physics
  • Explore conservation of momentum in various collision scenarios
  • Practice solving problems involving mass and velocity ratios
Students studying physics, particularly those focusing on mechanics and collision theory, as well as educators looking for examples of elastic collision problems.
fizics
A massless elastic cord (that obeys Hooke’s Law) will break if the tension in the cord exceeds Tmax. One end of the cord is attached to a fixed point, the other is attached to an object of mass 3m. If a second, smaller object of mass m moving at an initial speed v_0 strikes the larger mass and the two stick together, the cord will stretch and break, but the final kinetic energy of the two masses will be zero. If instead the two collide with a perfectly elastic one-dimensional collision, the cord will still break, and the larger mass will move off with a final speed of v_f. All motion occurs on a horizontal, frictionless surface.
Find v_f/v_0
m1v1=m2v2
I always got 1/sqrt(2), which is not the answer.
This is not an attempt at a solution. You have to show your work and explain your reasoning.
AM
oh,sorry,I know where I was wrong now,a stupid mistake.hehe
  • · Replies 32 ·
  • · Replies 22 ·
  • · Replies 24 ·
