Momentum and Impulse for a flywheel
To determine the time required for the flywheel to come to rest, first calculate the angular retardation (alpha) using the formula alpha = torque/moment of inertia. With a moment of inertia of 854 kgm^2 and a resisting moment of 14 Nm, alpha equals 14/854, resulting in an angular retardation of approximately 0.0164 rad/s². Next, apply kinematic equations to find the time, using the initial angular velocity of 0.785 rad/s and the calculated angular retardation. This will yield the time needed for the flywheel to stop completely.
richiecky
Hey. Just wondering if I could get a little help with this quest please.
A flywheel has a moment of inertia of 854kgm^s, and is allowed to come to rest from and angular velocity of 450rpm. Knowing that kinetic friction produces a resisting moment of magnitude 14Nm, determine the time required for the flywheel to come to rest.
well, i know that 450x(2pi/60) = 47.12 rad/min = 0.785rad/sec
so 0.785 is the intial angular velocity..
but am not sure where to go from here.
Could someone point me in the right direction please?
Thanks
Moment of inertia of the flywheel and torque on it is given. From thewse values find the angular retardation alpha, which is equal = torque/I. Then using kinematics find the time.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
