Momentum, elastically collisino, velocity
  • Thread starter Thread starter qomoco
    Momentum Velocity
The problem involves a pendulum consisting of a 0.200-kg mass that collides elastically with a 0.400-kg mass at rest on a frictionless surface. The pendulum is released from a horizontal position, and the task is to find the velocities of both masses immediately after the collision.
  • Participants discuss using conservation of energy to determine the velocity of the pendulum at the bottom of its swing before the collision. There are attempts to apply conservation of momentum and energy equations to find the final velocities after the collision.
Some participants have provided equations related to conservation laws and have attempted calculations. However, there is no explicit consensus on the next steps or the correctness of the calculations presented. The discussion includes various approaches and attempts to clarify the process.
One participant expresses uncertainty about the next steps after calculating the bottom swing velocity. There are also indications of a language shift in one post, which may not relate directly to the physics problem.
qomoco
A 0.200-kg mass is attached of a 0.800 m length string to form a pendulum. The pendulum is released from a horizontal position. At the bottom of its swing, it collides elastically with a 0.400-kg mass which is at rest on a horizontal, frictionless v surface. Find the velocity of each mass immidately after the collision.
p=mv
v1+v1f=v2+v2f
the answers are
v .2kg= -1.32m/s
v .4kg= 2.64m/s
but I need to know the steps so I can study for the tests.
When the mass is released from its initial position, what is its velocity at the bottom of the swing? (Use the conservation of energy to find this.) Then use the conservation of momentum and energy to find the velocities.
bottom of swing velocity = 3.96m/s(if I did right)
(3.96)(.2)=.2(x)+.4(y)
x y are the velocities, not sure how to do next now.
Je suis allé en France
J'étais à la banque quand
J'avais peur des chiens
Use law of conservation of energy.
1/2*m1v1i^2 = 1/2*m1*Vf1^2 + 1/2*m2*v2f^2-------(1)
According to conservation of momentum
m1v1i = m1v1f + m2v2f-----------(2)
From these two equations find v1f and v2f.
  • · Replies 22 ·
