Finding the Momentums of Two Cars in a System
  • Thread starter Thread starter kdizzle711
    Momentum System
The discussion revolves around calculating the individual momenta of a blue convertible and a red SUV based on their total momentum of 7500 kg*m/s, directed 65 degrees west of south. Participants suggest breaking down the total momentum vector into its southern and western components to determine each car's momentum. The next step involves using the mass of each vehicle to find their respective speeds. The conversation emphasizes the need to clarify the initial question regarding the speeds of both cars. This approach will lead to a solution for the momentum of each vehicle in the system.
kdizzle711
A blue convertible of mass 1500kg is traveling south, and a red sport utility vehicle of mass 2100kg is traveling west. The total momentum of the system consisting of the two cars is 7500kg*m/s directed at an angle 65.0 west of south.
Where do I start with this one?
what is the question?
What is the speed of the blue car?
What is the speed of the red car?
still looking for some start
Split the total momentum vector into the sum of a component pointed south and a component pointed west. That gives you the momentum of each car. Now find the appropriate velocities.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
