Momentum Principle question dealing with a spacecraft's velocity
The discussion centers on a spacecraft navigating in space, initially coasting at a constant velocity before firing thrusters for 22 seconds. The Momentum Principle is applied to calculate changes in momentum and velocity, with confusion arising around the correct use of equations for position updates. Participants highlight the importance of recognizing that the force is only applied for the duration of the thruster firing, after which the spacecraft resumes constant velocity. Misinterpretations of the equations and the force vector's components are noted as potential sources of error. Understanding the timing of force application is crucial for solving the problem correctly.
peachhcake
You are navigating a spacecraft in space. The mass of the spacecraft is 4.0 x 10^4 kg. The engines are off, and you're coasting with a constant velocity of ‹ 0, 28, 0 › km/s. As you pass the location ‹ 5, 6, 0 › km you briefly fire side thruster rockets, so that your spacecraft experiences a net force of ‹ 5.0 105, 0, 0 › N for 22 s. The gases have a mass that is small compared to the mass of the spacecraft . You then continue coasting with the engines turned off. Where are you an hour later?
Instructions say to use the step one of the Momentum Principle (p = Fnet(Δt)), then step one of the position update equation. I'm not sure if I am using the right equation, I think it's →rf = →ri + Vavg(Δt). I have also used pf = pi + Fnet(Δt), rf = ri + viΔt + 1/2(F/m)(Δt^2).
Well, when I first attempted the question, I used the Momentum Principle to find the initial momentum. After finding the initial momentum, I found the final momentum using the equation pf = pi + Fnet(Δt). I then found the final velocity by rearranging p = mv... then got stuck. I attempted to use rf = ri + viΔt + 1/2(F/m)(Δt^2), but that didn't result in a correct answer. I'm not sure if I'm misunderstanding the question, or the instructions.
Help is very much appreciated! Thank you so much.
How did you get stuck with p=mv?
It looks like you are trying to apply equations without understanding what is happening.
I notice that your force vector appears to have four components... but if I'm guessing correctly, the entire motion occurs in the x-y plane?
I'm not sure how you used the equation ... here are a number of ways that would be wrong ... i.e. Δt would only be for the time that the force was applied - 22s. Once the rockets stop firing you are back to constant velocity.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
