Momentum Question: Asteroid Collision
Asteroid A, moving at 40.0 m/s, collides with a stationary asteroid B of equal mass, resulting in A deflecting at 30.0° and B at 45.0° below the horizontal. The momentum equations derived from the collision indicate that the calculations for the final speed of asteroid A yield an unrealistic result of 78.2679 m/s, which contradicts the expected physics outcome. The correct answer, according to the textbook, is 23.3 m/s, prompting a reevaluation of the calculations. The discussion highlights the importance of careful algebraic manipulation in momentum conservation problems. The participants emphasize the need to verify the correctness of both their calculations and the textbook's answer.
student34
Asteroid A is traveling at 40.0m/s and collides with asteroid B which is at rest. Both asteroids have the same mass, but asteroid A deflects off of its path by 30.0° above the horizontal, and asteroid B begins to travel 45.0° below the horizontal. What is the speed of asteroid A?
PA1X = PA2X + PB2X
PA1X = 40.0m/s*mA
PA2X = mA*VA2*cos30°
PB2X = mB*VB2*cos45°
PA2Y = mA*VA2*sin30°
PB2Y = mB*VB2*sin45°
Equation #1 mB*VB2*sin45° = mA*VA2*sin30°
Equation #2 mB*VB2*cos45° + mA*VA2*cos30° = 40.0m/s*mA
I isolate mB*VB2 from Equation #1 and get mB*VB2 = (mA*VA2*sin30°)/(sin45).
Now I substitute mB*VB2 into Equation #2, and get (cos45°*VA2*sin30°)/(sin45°) + VA2*cos30° = 40.0m/s, I canceled out mA.
Next I isolate VA2*(sin30°)/(tan45°) + cos30° = 40.0m/s
Finally VA2 = 78.2679m/s which is impossible because it shouldn't go faster after the collision. Also, my textbook's answer is 23.3m/s.
Careful... didn't VA2 multiply both terms on the left?
Yup, 78 m/s is definitely too large. It's also possible that your textbook's answer is not correct :wink:
You're right - thank-you so much!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
