Momentum of Tennis Ball Question
A tennis ball with a mass of 110g traveling at 18.5 m/s east is struck by a racquet applying a force of 950 N west for 3.2 ms, resulting in a change in momentum of 3.04 kg m/s west. The discussion highlights the importance of impulse, defined as the product of force and time, equating to the change in momentum. Participants clarify that while the initial velocity is significant, it does not directly factor into the momentum change calculation. The correct approach involves using the impulse-momentum theorem to find the change in velocity after determining the change in momentum. The conversation concludes with the realization that the rebound velocity will not equal the initial velocity, correcting earlier misconceptions.
The Matador
A tennis ball with a mass of 110g is traveling 18.5 m/s east. It is struck by a racquet that applies a force of 950 N west. The ball and the racquet are in contact for 3.2ms. The change in momentum of the tennis ball is..
As far as I can tell p=mv and p=w/t are relevant to the equation
At first I tried to find the sum of the momentum before and subtract it by the sum of the momentum after, but that didn't seem to work. So I'm not really sure. Momentum has been my worst unit all year.
Any help would be appreciated. Thanks
So I figured if impulse is equal to the change in momentum then I could use the force and time in the equation to get the change in momentum.
so 950(3.2/1000) = 3.04
Which is the correct answer apparently (3.04 kg m/s, west).
What I'm still puzzled by is there is so much more info in the question. It appears to me that the velocity is not factored in at all. Should not mv = Ft ? (supposed to be a change in velocity, I can't find a triangle icon) Or is the change in velocity not 37m/s.
There's an important thing to remember; the change in momentum of an object is equal to the impulse [force] acting on it.
Right. Momentum is a vector, so direction is important.
Since you've found the change in momentum you can easily find the change in velocity (since you know the mass of the tennis ball) using:
\vec{F}\Delta t = m \Delta \vec{v}
But how did you get 37 m/s?
And once you correctly find the change in velocity, you can use the intial velocity to find the final velocity.
K thanks for clarifying that for me.
It was more of a brain fart on my part, I realized you can find the change in velocity using the equation, but it was different then what I guessed because the ball was initially going at 18.5 m/s then I figured it would be rebounding back 18.5 m/s so I thought the change in velocity would be 37 m/s. Which is in fact wrong. The velocity coming back is not going to be the same as it was when it hit the object.
Thanks for your help guys. I had a couple similar questions on a quiz in class today and got them correct.
