Solve Momentum Question: 5kg Object, 15 kg m/s, 8 m/s in 15s
  • Thread starter Thread starter zaga04
    Momentum
To determine the net force required to accelerate a 5kg object from its initial momentum of 15 kg m/s to a final velocity of 8 m/s over 15 seconds, the correct approach involves calculating the change in momentum. The formula F = deltaP/deltaT is applicable, where deltaP is the change in momentum and deltaT is the time interval. The initial momentum is 15 kg m/s, and the final momentum can be calculated using the mass and final velocity. The discussion highlights confusion regarding the correct application of formulas, emphasizing that acceleration should consider the initial velocity due to the object's existing momentum. Ultimately, the net force needed can be calculated accurately using the proper momentum change.
zaga04
1. A 5kg object has a momentum of 15 kg m/s. What is the net force required to accelerate the object to 8 m/s over 15 seconds?
A) .35N
B) 1.7N
C) 5.1 N
D) 11 N
E) 23 N
F=deltaP/deltaT
So I use that formula (which I am not sure is right). so wouldn't it be mv/t. So, (5)(8)/15 which is 2.67N which is not an answer choice.
I think I am using the wrong formula, but it's all I can think of! Please help.
The acceleration is not v/t in this case. The object has initial velocity because its momentum is 15 kg m/s before it starts accelerating.
