(Momentum) Two people on a platform
  • Thread starter Thread starter Mr. Box
    Momentum Platform
The discussion revolves around a physics problem involving two people on a platform and the effects of throwing a ball between them. The key point is that when the ball is thrown, the platform recoils due to the conservation of momentum, but the overall center of mass remains unchanged. Despite initial assumptions that the platform would return to its original position after catching the ball, the actual displacement is not zero. The participants clarify that the entire system, including the ball, people, and platform, must be considered to understand the motion accurately. Ultimately, the solution emphasizes the importance of the center of mass in analyzing the scenario.
Mr. Box
Two people are standing on a 2.0-m-long platform, one at each end. The platform floats parallel to the ground on a cushion of air. One person throws a 6.0-kg ball to the other, who catches it. The ball travels horizontally. Excluding the ball, the total mass of the platform and people is 118 kg. Because of the throw, this 118-kg mass recoils. How far does it move before coming to rest again?
Conservation of linear momentum:
(M1 * Vf1) + (M2 * Vf2) = (M1 *Vo1) + (M2 * Vo2)
When the ball is thrown forwards, the platform should accelerate backwards because the air resistance is negligible. When the other person catches the ball the platform should move back to its original spot because the momentum of the ball is transferred to the platform, so I thought the answer was a displacement of zero, but its not. Can someone show me what wrong with my solution?
what you actually have to take into consideration is Center of Mass. If initially before throwing the ball, the system was at rest, then all throughout the system should be at rest in the x-direction regardless of whether the ball is moving or is caught by the other person because no external force is acting on the system in x-direction.
System includes ball+both people+platform. essentially everything on the platform
Likes 1 person
I didn't even need to use linear momentum, thanks.
yeah, true. glad to help:smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
