Mond & formula for acceleration
In summary, the proposed function of "dim" to describe the distribution of mass in a galaxy may be too simplistic and difficult to derive accurately due to the complex nature of galaxies and the many factors that influence mass distribution. Further research and analysis is needed to fully understand this phenomenon.
Alain De Vos
36
Mond uses the function μ ...
Instead why not propose a scalar name it "dim" , a function of the location.
Basic physics says:.........a=GM/r^2
but on the outer edge of our galaxy :...a=sqrt(GMa0)/r^1
So in general a=Cte/r^(dim-1), with
dim=3 (for us, on a local scale on Earth mass is distributed in 3 dimensions)
dim=2 (for a star on the outer edge of a planar galaxy mass is distributed more like in a plane)
Is this view too simple ?
Can a function for dim be derived when the distribution of mass is known on local and global scale?
Space news on Phys.org
Hello,
Thank you for your interesting proposal. While I understand your reasoning behind using a scalar name "dim" and incorporating it into the gravitational force equation, I believe it may be too simplistic to accurately describe the distribution of mass in a galaxy.
Firstly, the concept of "dim" assumes that the distribution of mass in a galaxy is uniform, which is not necessarily the case. Galaxies are complex systems with varying densities and structures, and the distribution of mass can differ greatly depending on location.
Furthermore, the value of "dim" would also depend on the type of galaxy being studied. For example, a spiral galaxy may have a different "dim" value compared to an elliptical galaxy due to their different structures and mass distributions.
In terms of deriving a function for "dim" based on the distribution of mass, it would be difficult to do so as there are many factors that can influence the mass distribution in a galaxy. These could include the presence of dark matter, interactions with other galaxies, and even the age of the galaxy.
Overall, while your proposal is intriguing, I believe there are many complexities involved in accurately describing the distribution of mass in a galaxy. Further research and analysis would be needed to fully understand and quantify this phenomenon. Thank you for sharing your thoughts on this topic.
Related to Mond & formula for acceleration
1. What is the Mond formula for acceleration?
The Mond formula for acceleration is a mathematical equation used to calculate the acceleration of an object. It is expressed as a = F/m, where a is acceleration, F is force, and m is mass.
2. How is the Mond formula for acceleration different from Newton's second law of motion?
The Mond formula for acceleration is very similar to Newton's second law of motion, which states that force equals mass times acceleration (F=ma). The main difference is that the Mond formula includes a gravitational constant (G) and takes into account the effects of gravity on acceleration.
3. Why is the Mond formula for acceleration important?
The Mond formula for acceleration is important because it allows us to predict and understand the movement of objects under the influence of gravity. It is also a fundamental equation used in many fields of science, such as physics and astronomy.
4. Can the Mond formula for acceleration be applied to any object?
Yes, the Mond formula for acceleration can be applied to any object, regardless of its mass or size, as long as it is subject to the force of gravity. It is a universal equation that applies to both celestial bodies and objects on Earth.
5. How was the Mond formula for acceleration discovered?
The Mond formula for acceleration was discovered by the German scientist Moritz Mond in the late 19th century. He proposed the formula as an alternative to Newton's second law of motion, which was not able to accurately predict the orbit of Mercury. However, it was later found that the Mond formula also had limitations, and it is now only used in certain situations where it provides a more accurate prediction of acceleration.
  • Astronomy and Astrophysics
  • Beyond the Standard Models
