How can I expand sin(x + y) + sin(x - y) to get 2sinxcosy?
The discussion focuses on proving trigonometric identities, specifically expanding sin(x + y) + sin(x - y) to derive 2sinxcosy. Participants explore the right-hand side of the equation cos(x+y)cos(x-y) and attempt to simplify it, ultimately questioning whether their approach is correct. The left-hand side is successfully simplified using sine identities, confirming the identity holds true. Additionally, the conversation confirms that the second identity is indeed possible through proper expansion. The thread emphasizes the importance of using trigonometric identities for simplification in proving equations.
bubblygum
Proving trig identities
I have 2 more this time, thanks for the time!
-sin^2x-sin^2y+1=cos(x+y)cos(x-y)
Compound, double, pythagorean, reciprocal, quaotient, etc.
R.H.S.
cos(x+y)cos(x-y)
= (cosxcosy-sinxsiny)(cosxcosy+sinxsiny)
= cos^2xcos^2y - sin^2xsin^2y
Not sure how to finish this off. Or have I started it off wrong?
sin(x+y)+sin(x-y)=2sinxcosx
Same as above
L.H.S.
sin(x+y)+sin(x-y)
= sinxcosy+sinycosx + sinxcosy-sinycosx
= sinxcosy+sinxcosy
= 2sinxcosy
Consider using the Pythagorean identity on what you have come up with so far.
Great, solved it thanks.
Is the second one even possible?
Yes, just expand sin(x + y) + sin(x - y) using the sum and difference identities for sine and you'll get it.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
