More twin paradox and acceleration
In summary, the conversation discusses the twin paradox and two different explanations for it. One explanation, presented by Brian Greene, involves time dilation near a black hole or during high-acceleration turns. The other explanation, presented by David Butler, involves the acceleration effects of the turnaround. There is a debate over which explanation is more accurate, with some arguing that both gravitational time dilation and velocity-related time dilation play a role. Ultimately, the debate highlights the complexities of understanding time dilation and its various contributing factors.
DiracPool
1,243
516
I just came across this video today with Brian Greene talking about how time slows down for an observer near a black hole relative to an observer who is farther away. See the first two minutes:
It reminded me of another video I saw recently by David Butler where he states that the twin paradox can be resolved by looking at the time dilation factor of the traveling twin as being essentially fully a result of the turnaround acceleration effect producing more the equivalent of a gravitational time dilation effect (see 24:40):
Edit: I forgot to add this video, which is where he explains the resolution (see 17:17 in):
Such an effect would be similar to the one in the Brian Greene video. Thus, David Butler's position is that the twin paradox is not explained by Lorentzian time dilation due to relative velocity differences but rather to the acceleration effects of the turnaround. However, having read numerous threads in this forum on the twin paradox over the years, the consensus here seems to be that acceleration effects of the turnaround are not a significant factor in the time dilation effect but rather that it is simply the longer world line of the traveling twin that accounts for the paradox.
To be honest, the acceleration resolution makes more conceptual sense to me than the world-line solution does. If you look at the Brian Greene video and replace the black hole with a long, strong turnaround with high acceleration, it seems to make great sense. To this day I can't put my head around the world-line solution only to say that it seems to work mathematically and I'll have to take it on faith.
Is David Butler wrong? Please explain how. More generally, the question is what is responsible for or what makes a greater contribution to the age differences in the classic twin paradox experiment, gravitational time dilation or SR-velocity related time dilation?
If you describe the whole journey from the non-inertial twin's frame perspective, you will have to account (along with Lorentzian time dilation) for non-inertial-frame-effects (like position dependent time flow rate) to get the right age difference. Form any inertial frame Lorentzian time dilation is sufficient.
Depends on the reference frame.
I don't think that you can have the acceleration resolution without the world line solution. You have to use the worldline solution in order to calculate the amount of time dilation in the acceleration solution. I.E. the acceleration solution is simply a subset of the worldline solution.
Likes m4r35n357
Until you actually look at the underlying math, which makes it obvious that the two cases are very different, and that what similarities there are between them do not generalize to other cases. The "worldline solution", OTOH, is completely general; you can use it in any scenario whatsoever, even curved spacetime scenarios where neither twin feels any acceleration at all, but they still are different ages when they meet up again, which the "acceleration solution" can't explain at all.
This is why it's not a good idea to try to learn science from pop science sources. The video is a pop science source, even though Brian Greene is a scientist. Greene is a particular bete noire of mine in this regard, because he pushes the limits in his pop science more than just about any other scientist I know of. If you look at Greene's actual published, peer-reviewed papers, you won't find him saying the things he says in his pop science videos and books, because he knows he would never get away with them; his scientist peers would call him on it. But his pop science book publishers and video producers don't care, as long as it sells.
If you are the traveling twin, then you could use the gravitational time dilation approach during acceleration, but you will still have to factor in time dilation due to velocity. You also have to factor in the fact that the distance between you and your sibling is changing during your acceleration.
Remember, gravitational time dilation is tied to the difference in potential. So if you have a uniform gravity field, a higher clock is at a higher potential and runs faster(even if the strength of gravity does not change with height). For the accelerating observer, his acceleration is equivalent to a uniform gravity field and since his sibling is higher in that field, his clock runs faster( the further away he is, the higher in the field and the faster his clock runs as measured by the accelerating observer.) But since our observer is accelerating, two other things are occurring, the distance between him and his sibling is changing(thus changing the gravitational time dilation factor), and the velocity between the twin are changing(introducing a velocity dependent time dilation).
If you are the stay at home twin, you just need to deal with the velocity dependent time dilation. It is only for the accelerating twin that the equivalent gravity field used above exists.
1. What is the twin paradox and how does it relate to acceleration?
The twin paradox, also known as the clock paradox, is a thought experiment in special relativity where one twin travels at high speeds and returns to Earth, while the other twin stays on Earth. Due to time dilation, the traveling twin's clock will have slowed down, making them younger than their twin upon their return. This paradox illustrates the effects of acceleration on time dilation and the relativity of simultaneity.
2. How do we resolve the twin paradox and explain the discrepancy in age between the twins?
The discrepancy in age can be explained by the fact that the traveling twin experiences acceleration when changing direction, which disrupts the symmetry of the scenario. According to special relativity, time dilation only occurs in inertial frames of reference, meaning that the twin who accelerates will experience less time passing compared to the twin who remains in an inertial frame.
3. Can we apply the twin paradox to real-life scenarios?
While the twin paradox is a useful thought experiment for understanding the principles of special relativity, it is not applicable to real-life scenarios. This is because the effects of time dilation are only noticeable at extremely high speeds, such as those close to the speed of light. In our everyday lives, the difference in time between two objects in motion is negligible.
4. How does acceleration affect time dilation in the twin paradox?
Acceleration plays a crucial role in the twin paradox as it breaks the symmetry of the scenario and causes time dilation to occur. According to the theory of special relativity, an object in motion experiences time dilation, meaning that time appears to pass slower for them compared to a stationary observer. However, when the object accelerates, it enters a different frame of reference, and time dilation is no longer symmetrical.
5. Is the twin paradox a paradox or just a consequence of special relativity?
The twin paradox is not a true paradox but rather a consequence of the principles of special relativity. The apparent paradox arises when one applies classical, Newtonian principles to a scenario that requires the use of relativistic principles. By considering the effects of acceleration and time dilation, the twin paradox can be easily resolved and understood within the framework of special relativity.
