Motion dropping a stone: Time question
  • Thread starter Thread starter Jeff97
    Motion Time
The discussion revolves around calculating the time it takes for a stone to hit a moving leaf in a stream, given a distance of 35.75 meters. Participants debate the relevance of initial velocity and the need for specific formulas to determine the stone's drop timing. A key point is that the stone must be dropped 0.81 meters before the bridge to land on the leaf, considering the water's speed of 0.3 m/s and a drop time of 2.7 seconds. There is uncertainty about whether the initial problem and the bridge scenario are connected, highlighting potential gaps in the context provided. Overall, the focus is on understanding the physics of the drop in relation to the moving leaf.
Jeff97
A boy watches a leaf move down the stream at 0.30ms^1. He wants to drop a stone onto the leaf. Determine the position of the leaf at the instant when he must drop the stone.
I'll put one here once I know what one to use.
what I know d=35.75 t=? what am I meant to do with this problem? I'll add more to this area once I know some more. thanks. Is the leafs velocity considered inital? if so I know Vi
Jeff97 said:
I know d=35.75
What distance is this and how do you know its value?
Suppose he drops the stone when the leaf is underneath. What will happen?
@haruspex. I got the distance from the other problem, should I not be using it? If he drops the stone when the stones underneath him it will be past him once the stone reaches the leaf?
They sounded like completely different problems to me, but since I cannot see both in context I may be missing something. You do need to know the height from which the stone is being dropped.
Right, but assuming you know the height (call it d) by how much will he miss the leaf?
I suppose I need a formula? that contains d, Vi? t?
Yes, and one more (known).
Jeff97 said:
Vf? If so could you use d=Vi+Vf/2 t?
No, I wrote "known" (as an edit). You do not know Vf.
acceleration?
Perhaps you could forget formulas for a moment. Suppose this was a real task. You really have to hit something moving along a stream by dropping a stone on it. Imagine that you get lots of chances. Each time you miss, someone releases another leaf and gives you another stone. Let's assume you have a watch. How do you achieve the task?
Jeff97 said:
acceleration?
Yes.
Ok, so what we know is that he must drop the stone so that it will land on the leaf 2.7 seconds later. If the water is running at 0.3 m/s, then we can find the distance from the bridge to the leaf position (horizontal):
d=vt =0.3 x 2.7 = 0.81 m, so he must drop the stone when the leaf is 0.81 metres before the bridge.
The speed of the stone when it hits the water is not needed in the question. And I use the time from the first question.
That's all good, except that I am still not convinced the two questions are connected.
You refer to a bridge. There was no mention of such in post #1. Are you sure there's nothing else you've left out?
