Motion of a particle given position vector.
6 replies · 6K views
tcanman
A position vector of a particle at a time t is r=icost +jsint +kt ; show the speed and the magnitude of the acceleration is constant. Describe the motion.
v = dr/dt
a = dv/dt
Could someone let me know if I am doing this correctly?
I derived the position to find the velocity:
v = dr/dt = -isint +jcost + 1k
Then derived the velocity :
a = dv/dt = -icost -jsint
Then found the magnitude of the acceleration:
mag(a) = sqrt ( cos^2(t) + sin^2(t)) = 1 , which is constant.
Motion- increasing oscillation? How would I show this?
Thanks!
Don't forget to find the speed (magnitude of the velocity).
Think about just the two-dimensional [itex]x,y[/itex] motion. What kind of motion would that be? Then notice that the [itex]z[/itex] component just linearly increases in one direction. What kind of shape will be created this way? And how will your particle move along that three dimensional shape?
I took the magnitude of the velocity and got sqrt( sin^2 + cos^2 +1) so sqrt(2) , so it would also be constant.
Would the particle just be moving around a circle? How could I prove this?
Thanks!
Well, yes for the two-dimensional case it would be circular motion. If you don't recognize the form, try picking various values of [itex]t[/itex] and plotting them on a two dimensional graph to see it.
Is it supposed to look like a spring? And was I correct about the velocity?
Thank you for the help.
Exactly, it's the shape of a helix. The motion is circular, but it's traveling upwards along the surface of a cylinder with time.
And yes, you were right about the speed.
