Movement and Properties of Light
Light moves through space as electromagnetic (EM) radiation, with electromagnetic fields propagating outward from charged particles at the speed of light. When a charge moves, the EM field adjusts to the new position, but the field from its previous location continues to travel through space. Photons, which are the particles of light, do not possess their own electromagnetic fields since they are not charged. The delay in observing changes in light from distant sources, like the Sun, illustrates how the EM field takes time to reach observers due to the vast distances involved. Understanding these principles clarifies the movement and properties of light in relation to electromagnetic fields.
member 529879
How exactly does light move through space in terms of EM radiation and photons. What I'm confused about is the electromagnetic field. How does it oscillate, and in which directions? Also do photons have Electromagnetic fields associated with them?
Science news on Phys.org
Have you done any online research to try to answer this? Sometimes posting what you know and asking more specfic questions will help you to get answer quicker. :)
Likes member 529879
Charges cause electromagnetic field to propagate outwards from them in all directions at the speed of light. If the charge changes its position, the electromagnetic field is now propagating from the new position, but the electromagnetic field from the previous position is still traveling through space.
http://www.cabrillo.edu/~jmccullough/Applets/Flash/Electricity%20and%20Magnetism/EFieldOscillatingCharge.swf
No. Electromagnetic fields are caused by charge. Photons do not have charge themselves.
Likes member 529879
What do you mean by "the electromagnetic field from the previous position is still traveling through space"?
you obviously didn't look at the link that was provided ;)
Likes member 529879
So you can see that as radiating charge moves, the new radiating field moves with it, but the field that is still moving
from the original position keeps on going
think of this example ...
on a simple level ( without getting into relativity) someone with a flashlight shining it at you from in front of you
turns it off or moves it, you see it happening virtually instantly because of the high speed of the EM field ( the light) and your close proximity to its source
now let's move further away ... say the Sun
if it was suddenly turned off like a light globe ( your flashlight), You wouldn't know about it for 8 and a bit minutes
The EM field ( wave) takes time to travel from the Sun to the Earth over that ~140 million kilometres. The light traveling immediately prior to the blinking out of the Sun, is still traveling across that distance
how's that do for you ? :)
Likes member 529879
That helps thanks, and sorry for not clicking the link, it wouldn't open on my phone.
no probs :) its a good little animation
D
Likes member 529879
