Movement of a Ball Bearing within a cavity inside a Projectile
The discussion centers on the behavior of a steel ball bearing within a cylindrical cavity of a projectile when fired either straight up or at an angle. Initially, inertia keeps the ball at the back of the cavity, but as the projectile decelerates due to air resistance after firing, the ball moves to the front of the cavity. The significant deceleration caused by air drag, which can exceed gravity, influences the ball's position during flight. When fired straight up, the projectile's aerodynamic shape affects its descent, while the ball remains at the lowest point of the cavity. Overall, the ball's movement is predictable based on the projectile's trajectory and the effects of air resistance.
Gil Alard
Summary:: Question concerning the behavior of a ball bearing inside a projectile fired straight up or at an arc.
Within a projectile is a 1-inch cylindrical cavity, inside of which is a steel ball bearing that can freely roll along the length of the cavity. When the projectile is fired, inertia keeps the ball at the back of the cavity. Other than a quick deceleration (such as the projectile striking a surface), is there any situation in which the ball moves to the front of the cavity during flight? I'm specifically puzzled as to the ball's position if the projectile is fired straight up. Does the ball move to the front of the cavity as the projectile slows, turns, and then accelerates to terminal velocity? What about a very steep arc, like 80°?
Have you considered the effect of air resistance on the projectile?
In the absence of air resistance, why should the angle matter at all?
Edit:
In addition to air resistance (which is the elephant in the room), consider what happens if the ball and the projectile are less than perfectly rigid. While it is in the barrel of the gun, the ball is held strongly to the back of the cavity. This places a stress on the material and results in some minor deflection. Release the stress and there can be a rebound.
Last time I calculated the exterior ballistics of a projectile, the deceleration due to air resistance was 70 times the magnitude of the acceleration due to gravity. ( 70G ).
  • Wow
Likes jrmichler, jbriggs444 and berkeman
So there would be a shotgun effect. No different than a single projectile but in mass (normal shotgun in a wadding) with others, if you don’t count the marring of the shot surfaces. It could go just about anywhere or could it be controlled?
Welcome to PF.
The ball remains trapped within the closed projectile. The projectile trajectory and ball position is predictable.
The ball will be at the rear of the cavity while accelerating in the barrel. Immediately the projectile departs the barrel, it begins to decelerate due to air drag, at a significantly greater rate than one g. The ball will therefore be forced against the front of the cavity and will remain there for the period of deceleration greater than 1 g.
If fired directly upwards, the projectile and ball will become unstable as the projectile begins to fall back. The aerodynamic shape of the projectile will decide how it falls, while the ball will sit at the lowest end of the cavity.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
