Moving a box with a force that is less than gravity
The discussion centers on the feasibility of moving a box with a force less than its weight, focusing on the effects of friction and the angle of applied force. The equation for the force required to move the box, F_o(θ), incorporates the coefficient of kinetic friction and the angle of application. It is suggested that if the angle θ is chosen appropriately, specifically less than arctan(μ_k), the applied force can indeed be less than the gravitational force acting on the box. However, this condition may result in the box not moving if the frictional force exceeds the applied force. Ultimately, the relationship between friction and the weight of the box is crucial in determining whether it can be moved under these constraints.
kotchenski
The object is a box with a given mass m. Our person has the choice between pushing the box with a horizontal force, or pulling the box with a wire with an angle of θ=30o. The magnitude of Fo is the force vector he affects the box with in both cases.
Is it possible (If you can freely choose a value for θ) to keep the box moving without using a force fo that is greater than the gravity on the box
A drawing of the situation:
http://myupload.dk/handleupload/64d68oBb8KHy8
I believe I need an equation that describes the force Fo of θ, which I've found is given as:
F_o(θ)=\frac{\mu_k mg}{cos(θ)-μ_k sin(θ)}
I could choose to solve F'o(θ)=0 for theta which gives θ=arctan(μk)
This would describe the minimum force required but I don't know how to relate that to Fg
What is the relationship between friction and the weight of the box?
But what would the turning point tell you?
Don't you want to know where F0 < Fg
So if I use that Fnet(x)=Fo*cos(θ)-μn
And that Fnet(x)<0, then the value of θ<arctan(μ), and therefor I'm applying a force Fo that is less than gravity? Wouldn't that technically mean the box is not moving and is being held back by the friction?
Why would that be? Gravity is mg... and force less than mg would be less than gravity. To overcome friction it just has to overcome μmg.cos(θ) ...
