Moving object launched by observer into a Wormhole
  • Thread starter Thread starter Quds Akbar
    Observer Wormhole
Wormholes are theorized to transport objects through time and space, altering their position in space-time. When an observer throws a baseball into a wormhole, the baseball's trajectory changes, but this action does not impact the observer's own location in space-time. Each throw direction results in a different path for the baseball, demonstrating that its movement is independent of the observer. Dropping the ball into a wormhole leads to a distinct outcome compared to dropping it on the ground, but this does not create a paradox. Ultimately, the observer remains unaffected by the baseball's journey after it is thrown.
Quds Akbar
Wormholes usually send things through time and space, right?
So if an observer threw a baseball through a wormhole, the baseball's position in space-time would change.
However, can that action affect the observer's location in space and time, or would it create some sort of paradox?
You throw a baseball in one direction, it will follow one path through space-time; throw it in another direction and it will follow another path; don't throw it at all and it will follow yet a third path. Drop the ball into a hole in the ground and it will end up in a different place than if you drop it to the ground; drop the ball into a wormhole and it will also end up in a different place than if you drop it to the ground. There's no paradox here and the observer is unaffected by the path the baseball follows after it leaves his hand.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
