Moving wires in magnetic field/force
  • Thread starter Thread starter pujam3
    Magnetic Wires
When currents flow through two perpendicular wires, wire 1 along the x-axis and wire 2 along the y-axis, they experience forces due to their magnetic fields. The discussion reveals that wire 1 accelerates in the +y direction while wire 2 accelerates in the -x direction. The Right Hand Rule is applied to determine the direction of the magnetic fields and forces acting on the wires. The initial confusion about wire 1 moving into the page is clarified, leading to the correct understanding of their movements. Ultimately, the interaction results in specific directional accelerations of both wires based on their current flow.
pujam3
A long straight wire 1 lies along the x-axis. A long straight wire 2 lies along the y-axis so as
to pass very near, but not quite touch wire 1 at the origin. If both wires are free to move, what happens when currents are sent simultaneously in the +x direction through wire 1 and in the +y direction through wire 2? Note that “clockwise around origin” refers to an observer looking down on an xy plane in which +x is to the right and +y upward.
1. Both wires accelerate along the direction of current flow.
2. 1 accelerates in the −y direction, 2 in the -x direction.
3. Both wires rotate counterclockwise around the origin.
4. 1 accelerates in the +y direction, 2 in the -x direction.
5. Neither wire moves.
6. 1 accelerates in the +y direction, 2 in the +x direction.
7. 1 rotates counterclockwise, 2 clockwise around the origin.
8. 1 accelerates in the −y direction, 2 in the +x direction.
9. Both wires rotate clockwise around the origin.
10. 1 rotates clockwise, 2 counterclockwise around the origin.
None
I tried using the Right hand rule (#1) to find out the direction of the magnetic field on both wires, then i used the Right hand rule (#2) to find out the direction of the force to find out how it would move. I ended up getting wire 1 moving into the page, which doesn't seem right and is not in one of the answer choices.
Nevermind, Solved.
