Engineering What's the Difference Between MSc and MEng in Mechanical Engineering?
The discussion clarifies the distinction between a Master of Engineering (MEng) and a Master of Science in Engineering (MScEng) in mechanical engineering, highlighting that the MScEng typically requires a thesis while the MEng focuses on coursework. Employers tend to value the thesis associated with the MScEng more highly, potentially giving graduates an advantage in the job market. Admission requirements for the MScEng can vary by university, often necessitating a degree in engineering or a related field. There is also a noted difference in the structure and recognition of these degrees between the UK and the US, which can lead to confusion for prospective students. Understanding these nuances is essential for making informed decisions about graduate education in mechanical engineering.
doublemint
Universities offer a MEng in mechanical engineering, but what is a Master of Science in Mechanical engineering? What are the differences and what do they do??
Thanks
DoubleMint
Difference between an MEng and a MScEng is a thesis. MScEng is the one that has the thesis. MEng just has a bunch of grad level electives you can take to supplement your academic needs and or career.
I see. So how about the jobs that are offered to people with MScEng?
They are equivalent. Its just that employers hold more weight on the thesis - ie the MSc. So you would probably be put in a better position than someone who doesn't have one.
Thats cool. But one thing is confusing me...the graduate office for mechanical engineering at my university says I can enter MScEng with "A BSc Degree from a recognized university with a minimum four-year program or equivalent."
Does that mean BSc in ANY major??
Depends on the individual university requirements. The expectation would normally be a degree in engineering or a related subject (so if you're a particularly good physicist, for example). Have a chat with the admissions officer for that university if you need to know.
Also, I disagree with the response you had on the difference between an MEng and MSc in engineering. The MEng is an undergraduate degree, usually four years, of which the first three are effectively a BEng course. The final year takes your learning up to (but isn't necessarily all at) the level of an MSc. The MSc is a postgraduate course (hence the need for a prior Bachelors degree), nominally a year long.
I think there is a difference between the UK and the US(/other countries) here. Whilst what you say is correct for the UK, from what I understand, the comments that djeitnstine makes are correct for the US. Of course, since the OP doesn't specify a country, things will get a little confusing!
