Multi-Particle QM Homework: Hamiltonian & Vacuum State
  • Thread starter Thread starter binbagsss
    Particle Qm
binbagsss
Question attached :
Just number 1 please
Hamiltonian is given by eq ? In the attachment
##\phi(x_1,x_2,...x_n,t)= \int dx_1...dx_n \phi(x_1,x_2...x_n,t) a^+(x_1)...a^(x_n) |0> ##
Where ## |0> ## is the vacuum state and ##a(x) |0>=0##
[/B]
I can follow the solution and it make sense wanting to move the derivative from delta to the wave function, however, I thought the gradient operator would act on everything to the right, and so you would use a product rule here..so we would get a term where it acts in the delta and the w.f multiplies it as given, as well as and a term where it acts on the wave function and the delta just multiplies it
Solution continued here :
Many thanks
The ##\nabla^2## operator involves derivatives with respect to the coordinates associated with ##\vec x## and not with respect to the coordinates of ##\vec x_1## or ##\vec x_2##. Since ##\psi## is a function of ##\vec x_1## and ##\vec x_2##, but not of ##\vec x##, the operator ##\nabla^2## acting on the wavefunction gives zero.
When ##\nabla^2## acts on ##\delta^{(3)}(\vec x - \vec x_1)## you can show ##\nabla^2 \delta^{(3)}(\vec x - \vec x_1) = \nabla_1^2 \delta^{(3)}(\vec x - \vec x_1)## where ##\nabla_1^2## acts on the coordinates of ##\vec x_1##. This allows you to integrate by parts twice (with respect to the coordinates of ##\vec x_1##) to make ##\nabla_1^2## act on the wavefunction.
Omg, thank you !
binbagsss said:
Omg, thank you !
Hi ok I've done this but for the x integration to remove the dx and delta, there are no terms to replace x by ##x_1##. ... ?
There's the creation operator at the beginning of the integrand which depends on ##\vec x##.
This ##\vec x## will get replaced by ##\vec x_1## when integrating over ##d^3x## due to the delta function ##\delta^{(3)}(\vec x-\vec x_1)##.
A-ha I must be blind.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
