Multiple variable prediction interval
4 replies · 5K views
Uniquebum
Hey!
I'm working with some regression related stuff at the moment and i'd need some help with multiple variable prediction interval. Prediction interval for a single variable can be calculated using
[tex]PI = \hat{\beta_0}+\hat{\beta_1}x_i \pm t^* s_e \sqrt{1+\frac{1}{n} + \frac{(x_i-mean(x))^2}{S_{xx}}}[/tex]
where x can be thought as a 1 dimensional vector (or matrix/set) which holds the values x_0, x_1, x_2 and so on. Also, [itex]\hat{\beta_0}+\hat{\beta_1}x_i[/itex] is a linear regression line [itex]\hat{y}[/itex]. Finally, [itex]t^*[/itex] is the t-percentile, [itex]s_e[/itex] is standard deviation, [itex]n[/itex] is the amount of points in the sample and [itex]S_{xx} = \sum{(x_i-mean(x))^2}[/itex] from 1 --> n.
Now what does the equation look like for multiple variable regression?
I'd suppose [itex]\hat{\beta_0}+\hat{\beta_1}x_i[/itex] is easily changed to
[tex]\hat{\beta_0}+\hat{\beta_1}x_{0i}+\hat{\beta_2}x_{1i}+\hat{\beta_3}x_{2i}+...[/tex]
but what do i do with
[tex]\frac{(x_i-mean(x))^2}{S_{xx}}[/tex]
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
Off the top of my head, I would say that [itex]s_e[/itex] would be replaced by a cross-covariance matrix of the [itex]x_{j}[/itex]s and that the square root would be replaced by a vector where each element is calculated with the square root equation.
PS. Your equations should drop the i subscript where x is now an arbitrary input rather than the sample data point i.
PPS. I don't know which sign of the square root to pick. I think that an authoritative answer to your OP will take more expertise than I have.
You'll find formulae if you look in a book on multiple regression, linear models, or basic multivariate analysis. Essentially you replace the quantity you ask about with the matrix equivalent. If [itex]\widehat y[/itex] is the fitted value from the equation, and [itex]\mathbf{x}_0[/itex] is the specified value of the predictor, the interval estimate for the mean value of the response is
[tex] \widehat y \pm t \sqrt{\, \hat{\sigma}^2 \mathbf{x}'_0 \left(X' X\right)^{-1} \mathbf{x}_0 }[/tex]
If you want the interval for the particular value it is
[tex] \widehat y \pm t \sqrt{\, \hat{\sigma}^2 \left(1 + \mathbf{x}'_0 \left(X' X\right)^{-1} \mathbf{x}_0 \right) }[/tex]
Thanks a lot for the replies. I looked through a couple of books but they only talked about multiple variable regression in too vague manner. This'll help me get forward. Thanks again.
