Multiply matrices using threads
  • Thread starter Thread starter cs23
    Matrices Threads
The discussion focuses on a programming issue involving matrix multiplication using threads, where the user encounters segmentation faults. The main function initializes two matrices, A (18x16) and B (16x18), and attempts to multiply them in a thread function. The segmentation fault is likely due to not passing the correct parameters to the `pthread_create` function, as the thread function `compute_c_ij` requires an argument. A suggestion is made to pass the appropriate index to the thread function instead of using NULL. The thread implementation needs adjustment to ensure proper execution and avoid segmentation faults.
cs23
In my main function i am filling 2 matrices. Matrix A is 18x16 and MatrixB is 16x18. Then i am multiplying them in my thread function using an array of threads. However, i am getting segmentations faults when trying to run the program.
Code:
#include<stdio.h>
#include<pthread.h>
    int mata[18][16];
    int matb[16][18];
    int matc[18][18];
void* compute_c_ij(void* arg)
    int k;
    int n= *((int*)arg);
    for(k=0;k<16;++k)
        matc[n][n] += mata[n][k] + matb[k][n];
        pthread_exit(NULL);
int main()
    pthread_t thr[18];
    int n,m;
    int i,j;
    for(i=0;i<18;++i)
        for(j=0;j<16;++j)
            mata[i][j] = (i+1) +(j+1);
    for (i=0; i<16; ++i)
        for(j=0;j<18;++j)
            matb[i][j]= (i+1)+(2*(j+1));
    for (i=0;i<18 ; ++i)
     pthread_create(&thr[i],NULL,compute_c_ij,NULL);
     for (i=0 ; i<18 ; ++i)
      pthread_join(thr[i],NULL);
      printf("%d\n",matc[i][i]);
     pthread_exit(NULL);
Just an educated guess, but I don't think you are passing the right parameters into pthread_create. Your start function, compute_c_ij takes a parameter, and this is what should go in the 4th parameter of pthread_create (where you have NULL).
I found this example, which might be helpful, although much of it is in Spanish - http://www.dreamincode.net/forums/topic/53953-pthreadh/.
