Multiplying permutation cycles
  • Thread starter Thread starter fishturtle1
    Cycles Permutation
fishturtle1
Compute each of the following products in ##S_9## (Write your answer as a single permutation).
a) (145)(37)(682)
Theorem: Every permutation is either the identity, a single cycle, or the product of disjoint cycles.
I start with (145)(37)(682).
Going from the rightmost cycle to the left, starting with 6.. 6 goes to 8, 8 goes to 8, then 8 goes to 8. So 6 goes to 8.
So i have (68) so far.
Now 8 goes to 2, 2 goes to 2, 2 goes to 2. So 8 goes to 2.
Now i have (682).
Now 2 goes to 6, 6 goes to 6, 6 goes to 6. So 2 goes to 6.
Now i have (6826) and I'm going to have a loop like (682682682...). I'm not sure where to go from here. If I just skip to 7, like (6827), then 2 goes to 7.. but 2 needs to go to 6 somehow. Also, by the theorem, its true that a permutation cannot be expressed as a single cycle and the product of disjoint cycles. Its a product of disjoint cycles..so is what I'm doing impossible?
Your original product is a product of disjoint cycles. I believe the problem statement parenthesis should be "your answer should only contain disjoint cycles". It is unclear what "single permutation" means.
I asked here first to see if I could get a hint before looking at the answer key. It seems "single permutation" means the form:
\begin{pmatrix}
1 & 2 & 3 & 4 & 5 & 6 \\
\end{pmatrix}
I can take it from here, sorry for the weird question, I was trying to avoid the answer key on the very first question..
Ok, that makes sense. I just don't like that notation as it takes more space and is less transparent than cycle notation, but as a first exercise to get the hang of what it means I guess it is fine.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
