squenshl
- 468
- 4
- Homework Statement
- Consider the function ##f:\mathbb{R}^2 \rightarrow \mathbb{R}## given by ##f(x,y) := \ln{\left(3+(x+y)^2\right)}##.
1. Find ##\nabla f##, the gradient of ##f##, and determine at which points ##\nabla f## is zero.
2. Determine whether the critical points of ##f## are local minima, local maxima, or saddle points by considering the level curves of ##f##.
3. Calculate all the second order mixed partial derivatives of ##f##.
- Relevant Equations
- Gradient vector ##\nabla f##.
There are sets of the form ##\left\{(x,y)\in \mathbb{R}^2: f(x,y) = \ln{\left(3+(x+y)^2\right)} = c\right\}## where ##c## is some fixed number ##> 1##. Let's see what happens for a few values of ##c##.
Suppose ##c = 2##, then ##\ln{\left(3+(x+y)^2\right)} = 2 \Longleftrightarrow (x+y)^2 = e^2-3##, or ##x+y = \pm\sqrt{e^2-3}## which are straight lines of gradient ##-1## through ##\left(\pm\sqrt{e^2-3},0\right)## and ##\left(0,\pm\sqrt{e^2-3}\right)##.
For ##c = 1##, then ##\ln{\left(3+(x+y)^2\right)} = 3 \Longleftrightarrow (x+y)^2 = e^3-3##, or ##x+y = \pm\sqrt{e^3-3}## which are straight lines of gradient ##-1## through ##\left(\pm\sqrt{e^3-3},0\right)## and ##\left(0,\pm\sqrt{e^3-3}\right)##.
1. We find the partial derivatives of ##f## with respect to ##x## and ##y## to get ##\frac{\partial f}{\partial x} = f_x = \frac{2(x+y)}{3+(x+y)^2}## and ##\frac{\partial f}{\partial y} = f_y = f_x = \frac{2(x+y)}{3+(x+y)^2}##. This makes the gradient vector
$$\nabla{f} = \begin{bmatrix}
f_x \\
f_y
\end{bmatrix} = \begin{bmatrix}
\frac{2(x+y)}{3+(x+y)^2} \\[6pt]
\end{bmatrix}.$$
Equating these to zero gives the critical points and doing so gives ##2(x+y) = 0##, or ##y = -x##. Hence, the critical point is the line ##y = -x##.
2. From the figure above we see that the level curves seem to increase the further we get away from the critical points which suggests that they are local minima.
3. We have ##f_x = \frac{2(x+y)}{3+(x+y)^2}## which means ##f_{xx} = \frac{\left(2(3+(x+y)^2\right)-4(x+y)^2}{\left(3+(x+y)^2\right)^2}##. Similarly we have ##f_y = 2ye^{x^2+y^2}3## which means ##f_{yy} = \frac{\left(2(3+(x+y)^2\right)-4(x+y)^2}{\left(3+(x+y)^2\right)^2}##. Finally, we know that ##f_{xy} = f_{yx} = \frac{\left(2(3+(x+y)^2\right)-4(x+y)^2}{\left(3+(x+y)^2\right)^2}## since the (Hessian) matrix of second order partial derivatives is symmetric.
My question is what are the critical points if ##\nabla f = 0## implies ##y = -x##??
f_x \\
f_y
\end{bmatrix}.$$
