linux kid
- 101
- 0
If it's a magnetic shield, then it must be permeable. Right or wrong? I would like to know if mumetal is permeable.
marcusl said:Yes, a superconductor expels flux (perfect diamagnetism) for fields below a critical value, and can act as a non-permeable magnetic shield.
marcusl said:First of all mumetal doesn't reflect fields at all, it shields by guiding them through the metal. Think of when you go camping and make a little ditch around your tent to conduct water away if it rains. The ditch doesn't reflect water, it guides it along. Designing magnetic shields isn't rocket science but there isn't a simple formula either--it depends on configuration and shape of both the field and the shield, and also on the strength of the field and thickness of the mumetal. The shielding effectiveness drops dramatically if you saturate the material in a strong field, in which case multi-layer shields are used.
Here are some sites to get you started. You'll find many more with a google search.
http://www.advancemag.com/" , click on "Shield Design".
Here's a vendor that sells small quantities of mterials
http://www.lessemf.com/mag-shld.html"
and they have a design guide.
http://www.magnetic-shield.com/dynamics/works.html"
linux kid said:Thanks marcus for the explanation. You bring me to more questions. In the camp scenario, the water can be redirected down a slope to a river or something. What about in the case of the fields? Where does it go, into the air? Do magnetic field build up (eg. like heat) or does it always stay at a certain level?
You can however, get some Type IIs on eBay or any good electromagnetic effects-themed scientific toy website. You also need to rent a dewar for liquid nitrogen.linux kid said:Where can I buy some, do you know?
ranger said:The field moves through the mumetal (picture the magnetic field like field lines) because it has higher magnetic permeability than the air around it. The field lines originate from the north pole of the magnet then "flow" to the south pole, through the magnet itself then back out the north pole. Placing mumetal in the vicinity will simply create a sort of like a different path for the fields lines, but it will still flow from north to south through the mumetal. Please keep in mind that fields lines are abstract entities that are used to visualize the magnetic fields.
1. Yes, it goes back into the air.linux kid said:Thanks marcus for the explanation. You bring me to more questions. In the camp scenario, the water can be redirected down a slope to a river or something. What about in the case of the fields? Where does it go, into the air? Do magnetic field build up (eg. like heat) or does it always stay at a certain level?
light_bulb said:i was thinking of making my own brick funace just for this, some sand, stone coal and an accordian blower lol.
