Defending Against Nanotech Murder: Is It a Realistic Threat?
  • Thread starter Thread starter Loren Booda
    Nanotechnology
The discussion centers on the potential threat of nanotechnology being used for harmful purposes, such as a fly-sized robot delivering poison. Participants speculate on defense mechanisms against such attacks, suggesting the development of safe electromagnetic field generators to disable malicious devices. Additionally, the conversation highlights the positive applications of nanotechnology, including the creation of nano-mechanical antibodies that could protect against viruses and chemical threats. The feasibility of both offensive and defensive uses of nanotech is acknowledged, indicating a need for ongoing research and preparedness. Overall, the dialogue emphasizes the dual-edged nature of nanotechnology in security contexts.
Loren Booda
Might it be possible?
Speculation: a fly-sized robot injects a polonium into an unsuspecting victim.
How can we defend against such attacks? What other fronts must we protect from nanotechnology - a replicating mechanical virus?
Those are some far fetched ideas for weapons.. maybe it would be one day possible so as for defense I'm sure it would be possible to come up with a safe field generator that produces EM fields that would specifically disable such devices.
Or the "good side" of your ideas are you can have friendly nano-mechanical anti-bodies that would fight off viruses and chemical/radiation attacks.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
