Muzzle Velocity by Analyzing Ballistic Pendulum
The discussion focuses on deriving the muzzle velocity using conservation of energy principles in a ballistic pendulum setup. The user proposes an equation for muzzle velocity based on kinetic and gravitational potential energy, questioning whether their method is correct. They compare their derived equation with an alternative found online, which includes a mass ratio term. Participants emphasize the importance of understanding the type of collision involved and the conservation laws applicable to the scenario. Clarifications on the setup and variable definitions are suggested for better accuracy in the calculations.
ujellytek
Finding the equation for the muzzle velocity by using conservation of energy.
2. The attempt at a solution
Ek+Eg=Ek2+Eg2
Well I'm 100% sure the kinetic energy of the ball is transferred into the catcher. The displacement is 1.9cm which is 0.019m. Mb=0.0077Kg (mass of ball) Mc=0.085Kg (mass of catcher)
Here is my work: .5Mbv^2=Mc*g*h <- this is supposed to be the total mass because the Mc and Mb become one, right? (btw that's the method my classmates used)
My method: .5Mbv^2=(Mc+Mb)*g*h
eventually v=sqrt( (2*g*h*(Mc+Mb))/Mb )
3. Relevant questions:
Is the proper equation for the muzzle velocity? v=sqrt((2*g*h*(Mc+Mb))/Mb)
I went to check this online, and I found out that the equation is supposedly supposed to be
v=(1+Mc/Mb)*sqrt(2*g*h)
Your problem statement is rather spare. You should describe the setup and define the variables you'll be using.
You might want to rethink that. What type of collision is involved? What's conserved? What's not conserved?
Also, you may just want to double check that all of the values are correct.
