eloheim said:
Unless you're going to modify quantum mechanics with something like GRW's spontaneous collapse theory then I'm afraid you're stuck with superposition as a general principle. And since no deviation from linearity has shown itself despite steady progress towards larger and more complex superposition experiments over the years (not to mention research into quantum computers), the onus should fall on supporters of nonlinear dynamics to prove that their theory is the correct one.
It is accepted physics that electrons interact with each other via the mediation of the EM field, with the relevant interactions represented by
A ⋅ J, with
A being the vector potential and
j the current density. It is also accepted physics that
j is quadratic in
ψ and that
A is generated by the current of the other electrons. These nonlinarities prevent an analytic solution of even the two electron problem. So, we solve the problem with perturbation theory, using a sequence of linear approximations.
It is hard to see what objection there can be to applying these well-confirmed principles to bulk matter, such as quantum detectors. Any skepticism should be laid to rest by the fact that calculations based on nonlinear dynamics, such as Hartree-Fock method and the Gross-Pitaevskii approximation, show reasonable agreement with observations -- confirming the nonlinear view.
On the other had, linearity in bulk matter, which is bound by EEIs, is an unconfirmed postulate. It is underpinned by no accepted physics other than linearity working reasonably well for isolated quanta and small samples of matter. As the phase shift induced by nonlinear EEI terms increases with time and the number of electrons involved, the observed small sample quantum behavior is fully consistent with nonlinear EEI dynamics.
Thus, the burden of proof rests on those ignoring the known physics of EEIs by postulating macroscopic quantum superposition.
Finally, we need no gratuitous or
ad hoc assumptions to explain the collapse of the wave function. As long as quantum wave packets are far from bulk matter, EEIs can be safely ignored. Once the detection process begins, the incident quantum is interacting with the detector's electrons, and we can no longer ignore the nonlinear terms in the Hamiltonian. As the sum of solutions of nonlinear sets of equations is not a solution of those equations, a superpositions of states is no longer possible. So the wave function inevitably collapses.
