Why Does My Computer Say No Boot Filename Received?
  • Thread starter Thread starter The_Absolute
    Computer
The error message "No boot filename received" indicates that the computer cannot find the hard drive or the Windows installation. Possible causes include loose cables, BIOS settings not detecting the drive, or issues with the boot loader or system files. Users are advised to check physical connections and BIOS settings to ensure the hard drive is recognized and set as the primary boot device. If the hard drive is not detected, it may have failed, which is covered under warranty for the user's pre-built computer. The user has taken the computer for diagnostics and is prepared for potential hardware replacement.
The_Absolute
Yesterday, I was playing STALKER Clear Sky, a video game. Then I exited the game after I was done with it, and shut down my computer. I ate dinner, and then booted my PC back up. I got this error message.
"No boot filename received. disk boot failure, instert system disk and press enter."
What does this mean?
And what does "Boot from AHCI CD-ROM mean?" Is there any way I can fix this in the boot menu or BIOS settings? Because I can't get into windows vista. Is this a software problem? Or could my hardware be going bad? Corrupted windows registry?
Thankfully my desktop computer is still under full warranty. I'll probably take it into be repaired today, and it won't cost me anything.
Use this link to view detailed specs of my desktop PC if that helps any.
http://reviews.cnet.com/desktops/gateway-fx-6710-01/4507-3118_7-33346988.html?tag=mncol;rnav
Computer science news on Phys.org
It means that it can't find the hard drive or it can't find windows on the drive.
Check the cables for the drive haven't come loose.
Then check the bios detects the drive.
If it does then you can use your windows CD to boot and fix the windows installation
I'm going to have to reinstall windows? Does this mean I have to format my hard drive? It say's that it's trying to boot from the CD-ROM, windows is installed on my hard drive. I bought a pre-built computer, I don't believe I ever got a windows CD.
Windows was working fine immediately before this happened. I think if a cable came loose, I would have noticed some seIrious problems while I was using my PC. When I bought the computer, I didn't get any software with it. Everything was already installed, including windows vista. They told me to burn all the contents of my PC onto DVD rewritable disks. For data and system backup, for events like this. I would imagine that almost 200 GB worth of data would have had to have gone on over One Hundred DVD-RE.
I recently had a new, higher-wattage (750W) power supply installed to replace my stock 400W. Could this have done anything to the computer to cause this?
Do you know how to get into your BIOS setup? The first screen that you see when you turn on the computer should have two instructions on it: one should say something like "For system settings, press F2" or some other key like Del or Esc. The other should be the key to go to the Boot Menu or change Boot Options, which will allow you to boot from different devices. Press that button before the POST screen (Pre-Operating System Test screen, which displays basic input/output and hardware information. Some systems replace this screen with a system logo like "DELL" instead) disappears, and make sure you boot from your hard disk drive and not from CD/DVD. If it boots properly, then you need to go to the BIOS settings and change the setting to boot from the main disk drive. If the main disk drive is not listed, the drive has either physically malfunctioned, or it is not connected properly; check the physical power, IDE/SATA connections and the jumper setting if a jumper is present. If the drive is listed and is the first boot device in the BIOS settings, then something is wrong with your system files or the boot loader file is missing. This can occur due to corruption or virus activity.
In that case, is your system a brand name system? Which brand? It may include a hidden restore partition which will help you further, hence why you do not have a separate restore CD/DVD.
I took it into the place I bought it from for diagnostics/warranty repairs. The technicians said it is likely that either my hard drive has died. Thankfully, hardware replacement is covered under it's warranty. I'll just be out of a computer for a few weeks.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
