My Crazy math teacher says this is solvable
  • Thread starter Thread starter The Divine Zephyr
    Teacher
The math problem presented, \\x-\frac{x}{1}=\frac{12}{25}\\, leads to an impossible equation, resulting in 0 equating to a non-zero value, which indicates no solution exists. Participants suggest the original problem might be a typo, possibly intended to be \\x - \frac{x}{1} = \frac{12}{25}\\. It is emphasized that subtracting a number from itself cannot yield a positive result. The teacher confirmed that the problem was indeed a typo. The final consensus is that the equation as stated is unsolvable.
The Divine Zephyr
<br /> \\x-\frac {x}{1}=\frac{12}{25} ...then...\\x-x=\frac{12}{25}\\ ...then...0=\frac{12}{25}<br /> <br />
... I hope not...
Is there a way? It was on homework and he says that all of them have answers. He didnt direct any comment on this problem. btw, only the first part is actaully on the problem, the part after the first "then" is what I got.
Your problem has no solution in any field where 1 is the multiplicative identity, much less in the real numbers. The problem may have been a typo of x - 1/x = 12/25.
did the problem ask you to solve for x? x is not solvable...100%... period
that might be a typo or something alike...
you might want to make sure the question is not "is x solvable" j/k
A number "n" cannot be subtracted by an identical value and result in a positive value.
The answer could be something like "unsolvable."
Yeah, I emailed my teacher and he said it was a typo ;)
