How do you derive the two n choose k formulas?
  • Thread starter Thread starter zoxee
    Formula
The discussion focuses on the derivation of the two formulas for "n choose k": \(\dfrac{n(n-1)(n-2)...(n-k+1)}{k!}\) and \(\dfrac{n!}{k!(n-k)!}\). Participants clarify that the second formula can be derived by expanding \(n!\) and canceling out the \((n-k)!\) terms. The confusion arises from the multiplication by \((n-k)!\), which is not necessary for the derivation. Ultimately, the key point is that the two formulas are equivalent through proper manipulation and cancellation of terms. Understanding this relationship is essential for grasping combinatorial concepts.
zoxee
I always see two formulas for n choose k
the first one:
## \dfrac{n(n-1)(n-2)...(n-k+1)}{k!} ## and the second ## \dfrac{n!}{k!(n-k)!} ## just curious on how you get from one to the other
I multipled the first one by (n-k)! and got ## \dfrac{n(n-1)(n-2)...(n-k+1)(n-k)!}{k!(n-k)!} = \dfrac{n(n-1)(n-2)...(n-k+1)!}{k!(n-k)!} ## but not sure how to proceed... thanks
The *definition* of n! is n*(n-1)*(n-2)*...*3*2*1
The *definition* of (n-k)! is (n-k)*(n-k-1)*(n-k-2)*...*3*2*1
So, the *ratio* of (n!)/(n-k)! would be
[n*(n-1)*(n-2)*...*3*2*1] / [(n-k)*(n-k-1)*(n-k-2)*...*3*2*1]Comparing the two things in square brackets, every factor after n-k cancels between the numerator and the denominator. So, only factors larger than n-k remain in the numerator. So, what's left in the numerator would be n*(n-1)*(n-2)*...*(n-k+1)
EXAMPLE: n = 10, k = 3
n! = 10*9*8*7*6*5*4*3*2*1
(n-k)! = 7*6*5*4*3*2*1
dividing the two, we see that all factors below (n-k)= 7 cancel between the numerator and denominator, leaving you with 10*9*8. Notice that 8 = (n-k+1)
Just expand ## (n-k)! ## in the expression on the left hand side of the equals (the expression on the right hand side is a step backwards) and compare the numerator with ## n! ##.
Thank you both, got it.
the first one:
You did not multiply by ##(n-k)!## (nor should you). You merely expanded out ##n!## to get
\frac{n!}{k! (n-k)!} = \frac{n(n-1) \cdots (n-k+1) (n-k)!}{k! (n-k)!}.
Just cancel out the factors ##(n-k)!## from the numerator and denominator.
I did multiply out... I'm not sure what you mean
I don't see how to cancel out factors from this:
## \dfrac{n(n-1)(n-2)...(n-k+1)(n-k)(n-k-1)(n-k-2)!}{k!(n-k)(n-k-1)(n-k-2)!} ## all I see is the (n-k)! cancelling out
I'm trying to undersand how to get from ## \frac{n!}{k! (n-k)!} = \frac{n(n-1) \cdots (n-k+1)}{k!} ##
No. If you had multiplied by (n-k)! you would have written
\frac{n! (n-k)!}{(n-k)! k!} = \frac{n(n-1) \cdots (n-k+1) [(n-k)!]^2}{(n-k)! k!}.
That is not what you wrote.
I done this by using cephids eample...
## \dfrac{n!}{k!(n-k)!} = \dfrac{n(n-1)(n-2)!}{k!(n-k)(n-k-1)(n-k-2)!} = \dfrac{n(n-1)(n-2)...(n-k+1)}{k!} ##
I multiplied ## \dfrac{n(n-1)(n-2)...(n-k+1)}{k!} ## by ## (n-k)! ## obtaining ## \dfrac{n(n-1)(n-2)...(n-k+1)(n-k)!}{k!(n-k)!} ## sorry for not being more clear
