Naming Concentric Circles: What's the Best Approach?
  • Context: High School
  • Thread starter Thread starter faiz4000
    Approach Circles
The discussion revolves around the naming conventions for circles, particularly focusing on how to name concentric circles. Participants explore various methods of naming circles based on their centers and radii, and whether these methods are consistent or conventional.
  • Some participants propose naming a circle by its center, such as "circle O" for a circle centered at point O.
  • Others suggest that knowing the radius allows for a more precise naming convention, such as referring to the circle centered at O with radius r.
  • One participant questions the adequacy of naming circles solely by their center, arguing that a system similar to naming polygons (e.g., quadrilateral ABCD) should be applied to circles as well.
  • Another participant counters that polygons have vertices, which justifies their naming convention, while circles do not have vertices, making the center and radius system more appropriate.
  • There is a call for a unified naming convention that applies in all situations, with a request for a conventional rule that is documented.
  • One participant asserts that the center and radius method is widely accepted, including in formal educational curricula.
Participants express differing opinions on the best approach to naming concentric circles, with no consensus reached on a single method. Some support the center and radius approach, while others advocate for a naming system similar to that used for polygons.
The discussion highlights the limitations of existing naming conventions, particularly in how they apply to concentric circles, and the absence of a universally accepted rule for naming circles in all contexts.
faiz4000
how do you name a circle? Obviously you could name it by its centre example a circle with centre at O would be called circle O. but what if you have two concentric circles?
Knowing the radii, you could say the circle centered at O with radius r
it seems an odd way to name figures. for other things we use a set of points to name other types of figures. for example, quadrilateral ABCD. shouldn't the circle be named like that too?
Polygons have vertices, which is why they can be named using the vertices' names. This is the same as naming a circle by it's center, but that doesn't allow for uniquely naming concentric circles.
yes, but there must be unified way that works in all situations. does somebody know the conventional rule written somewhere for the purpose?? your method of using the radius seems OK but do you know that its the proper way?
Circles don't have vertices, so that system can't apply. The center and radius system is how everyone I know does it, including the federally-mandated curriculum.
  • · Replies 18 ·
