Necessary to remove an electron from the surface.
  • Thread starter Thread starter omni
    Electron Surface
Photon emissions from a metal surface can eject electrons when the frequency of the radiation exceeds 2.5 x 10^16 Hz. The kinetic energy of the emitted electron is calculated using the formula 1/2me*v^2, where 'v' is the electron's velocity. To find the energy necessary to remove the electron, the equation 1/2me*v^2 = hv - Φ is used, where Φ represents the work function. The user is advised to correctly distinguish between the electron's velocity and the photon's frequency in their calculations. Ultimately, the user aims to calculate Φ using the values derived from the formulas provided.
omni
it known that photon of Electromagnetic radiation Cause to an electron emission from Metal surface.
the velocity of the electron is 3.6*10^3km/h
i Calculate the Wavelength of the electron with the formula \lambda=h/m*v
it is written that when the frequency radiation are low than 2.5*10^16Hz so there are no any electron emission from the Metal surface.
now i asked to find how much energy are necessary to remove an electron from the surface.
so i need to use the formula 1/2me*v^2=hv-\Phi all i need is to find \Phi ?
thanks.
thanks.
Hello Omni.
You are using the variable "v" in two different ways. The v on the left hand side is the velocity of the ejected electron. The v on the right, likely should be the Greek letter ν (nu), which is the frequency of the photon. ( You might rather use f for frequency)
c = λ ν, where c is the speed of light.
yes that is correct.
"c = λ ν, where c is the speed of light." how this can help me here?
in this formula v is also mean nu (frequency )
but i need to find how much energy are necessary to remove an electron from the surface.
thank you.
You need the electron's Kinetic Energy to be greater than zero : KE > 0.
Use that with:
(1/2)meve2 = hf - Φ.
Find the frequency, f, then find λ .
thank you again.
so tell me if i correct:
1/2*(9.109*10^-31*(3.6*10^3)^2)=(6.626*10^-34*2.5*10^16)-\Phi
till here i correct?
thank you.
omni said:
thank you again.
thank you.
It looks good to me.
hi.
ok so all i have to do now is to find \Phi by doing hf-1/2me*V^2 and we know the value of each of this formulas as i showed before.
so i do like this: (6.626*10^-34*2.5*10^16)-(1/2*(9.109*10^-31*(3.6*10^3)^2))=\Phi
hope you can understand something in this mess :smile:
really thanks for your help.
