Nedd help finding weight over length
  • Thread starter Thread starter slayerus87
    Length Weight
To determine the weight a person would lift when picking up one end of an 1100-pound table at a 35 to 40-degree angle, the weight distribution changes based on the angle. Initially, lifting one end would mean supporting half the weight, approximately 550 pounds, but as the angle increases, more weight shifts to the grounded side. The minimum weight the lifted end must support can be calculated using the cosine of the angle multiplied by half the total weight. Additionally, the discussion suggests using force vectors and breaking the problem into x and y components for precise calculations. Overall, understanding the physics behind the angle and weight distribution is crucial for accurate lifting calculations.
slayerus87
what i mean is... i need to know how much a table weighs when picked up only at one end
the table is 1100lbs but we are only picking it up (one side only )at about a 35 or 40 degree angle. and also the table is 8 ft long
theres got to be a formula out there but I've been googling for about 30 min now and i havnt found anything
thanks for the help
i was just thinking, would the weight after lifting be half of the original
If the weight is distributed evenly, it is half when you first lift one end. As the angle increases, the amount of weight on the part on the ground increases, though how much depends on how the two sides are supported. The minimum weight the up side needs to support is, irrc, half the weight times the cosine of the angle. You might want to draw a diagram and check that - that's just off the top of my head. The minimum is with the person pushing perpendicular to the table surface (so at an angle when the table is angled to the floor).
If we convert 1100 lbs we get approximately 498.9567 kg and then times the Fg which is 9.8 N which equals 4,889.776 N. The you will have to split the problem into a y and x component to get the force the the table exerts when you lift it 35 or 40 degrees up.
yes u would haft to use force vectors and x and y components like the guy above me said.
thanks a lot guys
im sorry about reviving this thread but I am not going to lie to you...i have no idea how to do that. I've googled and tried on my own but i can't teach my self physics
i hate to ask but could someone do this for me:confused:
thank you all so much
If we assume the table is perfectly balanced and even then the math is actually pretty easy. The table is usually a 50/50 balance. You need to figure out how much weight is shifted to the other side. Take your angle in degrees (0 for flat, 90 for vertical) multiply by 0.0111... and then multiply half the weight by that to find how much is shifted. Example:
1100 / 2 = 550, that's your normal weight of each side.
40 degrees * 0.0111... = 0.444... * 550 = 244 shifted (306/794).
Again this won't take into account the fact that the legs add weight to the outsides, or if the table is not symmetric.
this gave me some trouble 2 would it be sin(40)/(550)=1/x i used law of sines
then x would be (550)/(sin40) oh i see then 244 shifted to the other side that makes sense so it woul be what u said above.
