Need formula for particular metal alloy, requirements inside
For a knife edge designed to withstand a 50 lb. load with minimal deformation, suitable alloys include hardened steel, tungsten, and high carbon steel, focusing on low malleability and high corrosion resistance. The application involves a two-point guitar tremolo system with a total tension of around 100 lbs. For the second contact point requiring low friction and slightly higher malleability, tool steel is recommended due to its low cost and availability in 1/8” thickness. Carbide is a more expensive option that offers minimal deflection and can be sourced in knife edge sections or ground from rectangular stock. Suppliers for these materials are readily available, ensuring accessibility for procurement.
Nutrient
If you have a knife edge (dual sided at 45°, 1/8" thick, and you want as little deformation as possible under a 50 lb. load, what would be the ideal alloy?
Harden steel?
Tungsten?
High carbon steel?
Application: two point guitar tremolo, total tension being around 100 lbs.
Looking for low malleability, shatter resistance, high corrosion resistance to salt, and no oxidation to air.
Second point of contact, second type of alloy needed:
Looking for least friction possible, slightly higher malleability.
This is metal on metal contact, with no lubrication to help.
Tool steel would be a good choice because it is low cost and widely available in 1/8” thick rectangular sections.
Slightly more expensive, but with the least possible deflection would be carbide, as before, widely available in 1/8” section as tool stock. The manufacturers of carbide can provide knife edge sections or you can grind it yourself with a diamond dressing wheel. Avoid the dust as it contains cobalt.
There are many suppliers, here is just one example...
http://www.use-enco.com/1/1/87935-solid-carbide-rectangle-rectangular-carbide-blanks.html
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
