NEED HELP Angle Dependence of Work
  • Thread starter Thread starter jwalant
    Angle Work
The discussion focuses on understanding the angle dependence of work in a physics lab context, specifically regarding the relationship between a Newton scale reading and the horizontal component of force. The user seeks clarification on how to calculate the horizontal force component when given an angle, using the formulas Fx = F cos theta and Fy = F sin theta. They provide specific values, including mass, distance, angle, and Newton scale reading, but express confusion about the terminology used in the question. The user is particularly interested in how the Newton scale reading relates to the horizontal force exerted by the mass in a scenario involving a cart and pulley system. Overall, the thread highlights the need for a clearer understanding of force components in physics problems.
jwalant
Hi ppl..
I have to hand this questions about Physics on Dec 6th.. & I really need help on it... Plz if possible answer this question. I will love to help someone in other way. Thx in advance :)
This is a question on Lab:Angle dependence of work
1) What is the relationship between the Newton scale reading and the horizontal component of the force exerted by the mass?
2) how to find horizontal component of the force mass?
if u are given an angle, then just use Fx = F cos theta, Fy = F sin theta
Thx for reply ,, BuT
I do have an angle.. for the first part i have 0.1 kg, distance=0.1m, angle=70*, N=0.2
but the question asks for Horizontal component of the force mass. Y does it say mass??
this is about the cart pulled away by Newton's scale and mass hangin over the pulley problem.
and you wht is the relationship between Newton scale reading and horizontal component of the force exertd by the mass ?
Do I use m*N?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
