Need help converting battery clock to DC
The discussion revolves around converting a battery-operated clock to run on DC power. Participants explore the configuration of the clock's battery setup and the implications for power supply requirements.
  • One participant describes the clock's battery configuration, noting that it uses two D batteries, with a specific wiring setup.
  • Another participant suggests that the batteries may be in parallel, but emphasizes the need to trace the wiring for confirmation.
  • A question is raised about whether the amperage of the power supply matters, with responses indicating that higher amperage may be necessary for proper function.
  • One participant confirms that the clock operates with just one battery, supporting the idea that the batteries are likely in parallel.
  • Another participant expresses interest in a similar setup involving different battery configurations, questioning how it would work with 4xAA batteries in series.
Participants generally agree on the need to determine the battery configuration and the importance of amperage, but there are multiple competing views regarding the specifics of the power supply requirements and configurations.
There are unresolved questions about the exact wiring and power requirements, as well as the implications of using different battery types and configurations.
Individuals interested in modifying battery-operated devices, particularly those with knowledge of electrical configurations and power supply considerations.
grime
I have a clock that eats up the batteries it runs on pretty quickly, and so I would like to convert it to run on DC power.
The clock has a total of 2 D batteries, 1 in each "foot" of the clock (they are separate). There is a white wire that starts at the + side of one battery, goes over to the + side of the other battery, then into the motor. There are 2 black wires that connect to each - side of each battery and then into the motor. The 2 black wires do not connect to one another (unless it is inside the motor assembly).
Can anyone assist in getting me started?
Thanks in advance.
Batteries are DC. You mean you want to use an AC to DC power source?
It sounds like the batteries are in parallel, but it is tough to know without tracing out the black wires. But once you do figure that out, you can get a power supply at Radio Shack to provide the needed 1.5V or 3V power.
Welcome to PF.
Thanks for the quick reply, Russ.
So if it's parallel, I need 1.5V, correct? Does the amperage of the power supply matter at all?
So, take one battery out and see if it still runs OK. If the batteries are in parallel, it's just for longer-lasting battery life.
Id like to see the answer to this as well, as I'm considering setting up an instrument to take energy sources toggle-able between its native batteries and a modded 240 adaptor.
It seems to run fine on 1 battery, so it looks like they are in parallel.
Duh, I should have thought of that.
Yes, typically D cell batteries supply higher amperage and amp hours (battery life). If it runs fine on AAA batteries or smaller then amperage is not a problem but it sounds like a higher amperage clock, 1 amp should be enough.
Im not meaning to hijack your thread here but seeing as this guy seems to know what he's talking about and only one guy's posted help in my thread, how would this work out for 4xAA in series?
  • · Replies 22 ·
10K
  • · Replies 68 ·
16K
