Need help in controlling the speed of DC Motor ?
The discussion revolves around controlling the speed of a DC motor in four quadrant operation without the use of microcontrollers or PLCs. Participants explore various methods to achieve this, including keyboard input for speed settings and alternative control mechanisms.
  • One participant seeks guidance on controlling a DC motor's speed automatically using keyboard input, specifically without microcontrollers or PLCs.
  • Another participant suggests using PWM of the drive voltage via an H-bridge to control the motor, questioning the avoidance of microcontrollers for PWM control.
  • A participant proposes using a DC generator attached to the motor's shaft to calibrate output voltage with speed, expressing uncertainty about implementation.
  • One participant raises a question about reading keyboard input without a computer, indicating a potential challenge in the proposed method.
  • Another participant suggests abandoning the keyboard interface in favor of a volume adjusting type regulator to set a fixed speed.
Participants express differing views on the feasibility of using keyboard input for speed control, with some questioning its practicality while others propose alternative methods. The discussion remains unresolved regarding the best approach to achieve the desired motor control.
Participants have not reached a consensus on the methods for speed control, and there are uncertainties regarding the implementation of proposed solutions, particularly in relation to the keyboard interface and calibration processes.
Er.Electrical
Need help in controlling the speed of DC Motor ??
Can anyone of genius mind here tell me how to control the speed of dc motor in four quadrant operation automatically without using microcontroller or PLC ??
I Want to do a mini-project where i want to setup a speed from a keyboard input so that motor will rotate in that speed ??
You would use PWM of the drive voltage via an H-bridge set of switch transistors to control the DC motor. Why don't you want to use a uC to control the PWM waveforms? You will need to do some calibration of PWM --> speed anyway, so using a uC will let you put that table in its memory...
actually its a challenge from my friend.They want me to do such things.Initally i thought to use a dc generator with the shaft of the motor and calibrate the output voltage with speed.output of this generator is converted to digital and comapre with desired speed.but don't how to implement it.So if you can guide me there,i ll feel relax
i wanted to see how you read a keyboard without a computer...
Yah..its impossible but forget the keyboard interface.Lets tale an volume adjusting type regulator.Just i want to fix a speed by anymeans
