Need help with a Bernoulli(?) expression
The expression "PV + mgh + 0.5mv^2 = constant" is a formulation related to Bernoulli's equation, reflecting the conservation of energy in fluid dynamics. Participants in the discussion debate the correct interpretation, with options focusing on energy conservation per unit volume, mass, or incompressible fluids. Some suggest that dividing the expression by volume leads to the classic Bernoulli equation, indicating its relevance. The conversation highlights confusion over the equation's components and their physical meanings, emphasizing the need for clarity in understanding fluid dynamics principles. Ultimately, the question appears to test recognition of Bernoulli's equation in a different context.
Rajasti
Hello! So this is my problem here, there's a question I've been studying for an exam in which I really can't understand the answer. Basically it has multiple choices and I'm very undecided. So this is it:
Expression: "What does this expression reflect? PV + mgh + 0,5mv^2 = constant "
a) Conservation of energy per volume unit, within an ideal fluid;
b) Conservation of energy per mass unit, within a Newtonian fluid;
c) Conservation of energy for an incompressible fluid;
d) None of the above. It's simply Bernoulli's Equation;
Which one is correct? Please help!
What are the units of the equation?
This is all the question description has. No mention of units of any kind :/
Rajasti said:
This is all the question description has. No mention of units of any kind.
You can just pick a system of units, such as metric units, and see how that effects the equation you have.
Likes russ_watters
Where did you get this equation from? It is definitely not the Bernoulli equation as I know it. What is m, V, and h in your relationship?
Looks like they multiplied-through by volume (V)?
What does it even mean physically to do something like that?
Well, believe it or not, this weird question has been present in my teacher's exam several years now. And today I'm having this exam and I'm afraid this crappy question comes up. I've asked here, reddit, asked physics friends. I've had some say is A), some say it's D). I am desperate here, and at this point Imma have to risk one of them through intuition or something. Can't seem to unite a consensus :(
What it seems to me is cinetic energy (0,5mv^2), potencial energy (mgh) and something relates to energy in PV as in Pressure * Volume. But I have no idea what this is either.
A friend of mine said that if you divide this expression by V, you get P + rhogh + 1/2rhov^2, this because rho (specific mass) = m(mass) / V (volume) and then you get Bernoulli equation. So he said maybe D). Just a stupid way for the teacher to test if we recognize Bernoulli equation in a slightly different setting...
I've read/laerned about at least three ways to obtain the Bernoulli equation, one of them was to derive it by starting with the conservation of energy of an incompressible fluid without losses (friction). So for me answer c) could be the right one. Dividing it by the volume yields the "classic" Bernoulli equation, every pupil hears about in school.
EDIT: ..and of course no heat transfer.
Likes russ_watters
And both kinetic and potential energy are forms of_____? C'mon, I think I know what the teacher is getting at and it really is that easy!
Next, since it is obviously at least related to Bernoulli's equation, what are the required assumptions/constraints on Bernoulli's equation?
I think that is the purpose and if so, the fact that you and your classmates are having so much trouble with it proves it isn't a stupid question but a necessary one!
You might use this [nearly]exact equation (with or without a time factor) to describe the function of a hydroelectric dam, for example. As @stockzahn pointed out, this just takes Bernoulli's equation back to the conservation of energy statement it came from (you can view it from either direction).
I thought the answer was given away already, but since there are still questions, try eliminating wrong options. If you used my suggestion of using metric units for the terms of the equation is each term a value of a) energy per unit volume or b) energy per unit mass or c) just energy?
