How Do You Apply Fourier Transform to sin(2t)/t?
CE Trainee
1. Homework Statement
f(t) = (sin(2t))/t
3. The Attempt at a Solution
I know that sin(t)/t has the Fourier transform pi(w). I'm just not sure how to apply that fact to this problem. Knowing that sin(t)/t --> pi(w), I reasoned that sin(2t)/t --> 2pi(2w). I'm almost certain this is incorrect. I arrived at this conclusion by noticing that if i multiplied the top and bottom of sin(2t)/t by 2, I would have a sinc function 2sinc(2t). Then I could use the property sin(t)/t --> pi(w). Am I anywhere close?
f(t) = (sin(2t))/t
You have the right idea. Let's introduce the following notation:
h(t) = \frac{\sin(t)}{t}
and H(\omega) is the Fourier transform of h(t).
Notice that
h(2t) = \frac{\sin(2t)}{2t}
and so
f(t) = 2 h(2t) = \frac{\sin(2t)}{t}
Therefore you need to find the Fourier transform of 2 h(2t)[/tex].<br /> <br /> Now suppose I write<br /> <br /> g(t) = h(2t)<br /> <br /> and let G(\omega) denote the Fourier transform of g(t). Do you know (in general, not necessarily for a specific function) how G(\omega) can be expressed in terms of H(\omega)? If so, then you are essentially done, because<br /> <br /> \mathcal{F}(f(t)) = \mathcal{F}(2 h(2t)) = 2 \mathcal{F}(h(2t)) = 2 \mathcal{F}(g(t)) = 2 G(\omega)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
