How Do You Solve Piecewise Calculus Functions?
  • Thread starter Thread starter CJ256
    Calculus
CJ256
Note: The functions above are in piece wise form, I just didn't know how to put them in piece wise function here.
http://www.mathway.com/math_image.aspx?p=SMB02LSMB03x:-1,-xSMB02ESMB032SMB02eSMB03+2SMB02lSMB03?p=87?p=38 = 1
http://www.mathway.com/math_image.aspx?p=SMB02LSMB03x:-1,4x+5SMB02lSMB03?p=83?p=38 = 1
1/1 = 1
Answer: limit as x approaches f(x) = 1
I'm not sure what your question is..
Your answer is correct
Edited the question! Hopefully you will be able to see it and understand it and help me out.
I understand the question in the image but I don't understand your question
I'll try and explain piecewise functions but I may be going in the wrong direction
your f(x) can be thought of as two separate functions in the two separate areas, when x is greater than or equal to -1 we treat the function as 4x+5
when x is less than -1 we treat the function as -x^2 + 2
In trying to find the limit, in this simple case you can just evaluate the function at x=-1. So we would use the region where x is greater than or equal to -1 and get -4+5 = 1.
I'm assuming this is all that you're expected to be doing since it seems like this is an early calculus class that isn't going to be all rigorous.
I attatched a graph of your function if it will help
So the answer to my question is just limit as x approaches -1 f(x) = 1 ? And will it be acceptable for me to just show the two cases that I have in my original answer, where I have plugged in a -1 every where I have an x?
1/1 = 1
While it is true that \displaystyle \lim_{x\to-1}\,f(x)=1\,, what you wrote isn't quite what you need to say.
Also, what does 1/1 = 1 have to do with this question ?
You need to show that \displaystyle \lim_{x\to-1^-}\ f(x)=\lim_{x\to-1^+}\ f(x)\,. If that is true then that common result is the limit you're looking for.
While it is true that \displaystyle \lim_{x\to-1^-}\ f(x)= \lim_{x\to-1}-x^2+2\,, and \displaystyle \lim_{x\to-1^+}\ f(x)= \lim_{x\to-1}4x+5\,, you really should state that this is what you're doing.
So can I just rewrite your last sentence and add something like:
The above statements hold true therefore limit as x approaches -1 f(x) = 1. I mean would that be an acceptable answer?
As an instructor I would want you to indicate that you're taking a limit as x approaches -1 from the left, and taking a limit as x approaches -1 from the right.
That may be picky on my part, and many of my students would agree.
