Need Help with Conversion Problem
  • Thread starter Thread starter torda87
The vehicle's acceleration is 7 km/h², indicating that its speed increases by 7 km/h every hour. The confusion arises from converting this acceleration into a speed change per second. The correct conversion shows that the speed change per second is 0.0019 km/h, not km/s. The issue may stem from the required significant digits or formatting in the online homework system. Ultimately, the answer should be expressed as 0.0019 km/h, aligning with the acceleration given.
torda87
A vehicle moves in a straight line with an acceleration of 7km/h^2. By how much does the speed change each second? Answer in units of km/h
Was trying to convert to seconds and got 0.0019km/s but not sure from there.
If someone could help that would be great.
I believe your answer is right. Just fix up your units.
I tried the answer and supposedly it is wrong. 0.0019km/s = 7km/h tried both and still got wrong answer. I am really confused.
The number 0.0019 is right, but not the units km/s.
If i convert back to hours then 0.0019km/s is 7km/h. Not sure if that is what you meant?
What I meant is that for you final answer, the number 0.0019 is correct, but it is not followed by the unit km/s. Rather, it is followed by the unit km/h. So the answer is 0.0019 km/h.
My homework is for an online course and the units do not matter in the answer section. Unfortunately it says 0.0019 is a wrong answer.
Were you supposed to put in a certain number of sig digs? Because the answer is 7/3600.
