Need Help With Identifying My Precipitate, .
  • Thread starter Thread starter justinh8
To verify the solid is Copper Hydroxide, conduct tests by adding ammonia solution and a strong acid solution to observe the reactions. The solid may appear pale blue when dry, but it can turn black when wet due to its reaction with water. Drying the sample may be challenging, as it could remain in a solution with a blue precipitate. These tests will help confirm the identity of the precipitate. Proper identification is crucial for accurate results in your chemistry work.
justinh8
Hi, i need some help on how to identify,
I mixed Copper Sulfate solution with Sodium Hydroxide solution to produce solid Copper Hydroxide and aqueous Sodium Sulfate. I than filtered out the aqueous sodium sulfate and was left with solid copper hydroxide. My teacher than asked me to verify that my solid was Copper hydroxide. How can i verify that my solid is Copper Hydroxide?
Please explain and help, Thanks!
Is it pale blue when dry?
if its wet it will react with water and form copper hydroxide which is black.
(I grabbed this from wikipedia)
Drying it won't be easy, I guess you have just a solution containing blue precipitate.
Check what happens when you add an ammonia solution. Check what happens when you add a strong acid solution.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
