Need Help with Linear and Angular Motion Homework?
The discussion revolves around problems related to linear and angular motion, specifically involving calculations of acceleration, velocity, and rotational dynamics. The original poster presents multiple questions involving a vehicle's acceleration, a rotor's speed change, and the velocity of a belt in a drive system.
  • Participants discuss the original poster's calculations for acceleration and velocity, questioning the assumptions made regarding the vehicle's speed change over time. There is also an exploration of the calculations related to the rotor's acceleration and angle turned, with some participants suggesting the need for proper notation and checks for consistency. The approach to calculating the belt's velocity is also examined, with attempts to apply relevant formulas.
The discussion is ongoing, with participants providing feedback on the original poster's attempts. Some guidance has been offered regarding the need for clarity in formulas and assumptions, and there is acknowledgment of the correctness of certain calculations. However, there is no explicit consensus on the overall solutions or methods being employed.
Participants note potential issues with the assumptions made in the original poster's calculations, particularly regarding the vehicle's speed and distance covered. There is also mention of the need for proper notation in mathematical expressions, which may affect the clarity of the problem-solving process.
JohnP60
Need a bit off help with these questions would appreciate some help.
1. An accelerating vehicle crosses a datum with a velocity of 20m/s and then covers a distance of 2.5km in 50s. Calculate the acceleration, and the velocity reached after it has traveled 2.5km.
2. If a rotor is rotating at 2000 rev/min accelerates to 3000 rev/min in 6 seconds calculate its acceleration and angle turned through.
3. Calculate the velocity of a belt in a belt drive system where the pulley is 82.3cm diameter and rotates at:
a) 1750 rev/min
b) 40 rev/s
1. a=v-u / t
20/50 = 0.4m/s^2
v=u+at
20 + 0.4 x 50 = 40m/s
2. 314.16 - 209.43 / 6 = 17.5 rad/s^2
w= wo t + 1/2 a t^2
1256.58 + 315
= 1571.58 rad
3. Unsure how to do this one
Thanks
JohnP60 said:
1. a=v-u / t
20/50 = 0.4m/s^2
This assumes the velocity changes by 20m/s in 50 seconds. You don't know if that is true.
JohnP60 said:
v=u+at
Simple cross-check: if the vehicle drives with a speed between 20m/s and 40m/s, in 50s it cannot go further than 40m/s*50s = 2km. Certainly not 2.5km.
Checks like those are useful to see if your answer can make sense.
There are missing brackets, but this problem will vanish with proper fractions on paper.
I can confirm your answer.
3. The pulley is a circle, the belt is moving at the outer edge with the same speed as this outer edge.
Unsure what you mean with Q1. Am i using wrong formulas?
had a go at 3.
a)V=Rw
0.41x183.26
=75.14m/s
b)V=Rw
0.41x251.33
=103.04m/s
Yes.
3 looks good.
As a general remark, it is easier to understand what you are doing if you start with a formula, and with the values given in the problem statement.
  • · Replies 17 ·
