Need help with linear independence proof
dyanmcc
Hi,
I don't know how to do the following proof:
If (v1, ...vn) are linearly independent in V, then so is the list (v1-v2, v2-v3, ...vn-1 -vn, vn).
I can do the proof if I replace 'linearly independent' with 'spans V' ...so what connection am I missing?
Thanks much!
Prove it by contradiction. If the second set of vectors was not linearly independent, then you can write 0 as a linear combination of those vectors. Then simply expand out each vector to show that this implies v1...vn are also linearly dependent.
Great thanks. Here's another one for you...Prove that if V is finite dimensional with dim V > 1, then the set of noninvertible operators on V is not a subspace of L(V)
What have you done for that second problem dyanmcc? Start by thinking about matrices.
Also be sure to prove that there is still a nonzero coefficient when you expand the vectors out. (look at the FIRST nonzero coefficient before expansion)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
