What is the reaction of the floor of the elevator on the boy?
  • Thread starter Thread starter rachael
    Elevator Reaction
The discussion revolves around the forces acting on a boy standing in an elevator, specifically focusing on the weight and the reaction force from the elevator floor. Initially, the boy's weight is calculated using the formula w=mg, resulting in a weight of 650 N. When the elevator accelerates upwards at 1.0 m/s², the reaction force increases, making the boy feel heavier, while during constant velocity, the reaction force returns to his weight. If the elevator were to accelerate downwards, the reaction force would decrease, causing the boy to feel lighter. Understanding these concepts involves analyzing the forces at play and how acceleration affects the perceived weight.
rachael
8 A boy of mass 65 kg stands on the floor of an elevator.
a What is the weight of the boy?
b What is the reaction of the floor of the elevator on
the boy?
The elevator starts to move upwards with an
acceleration of 1.0 m s–2.
c What is now the reaction of the floor of the elevator
on the boy?
After accelerating upwards for 2.0 s the elevator
continues with a constant upwards velocity.
d What is now the reaction of the floor of the elevator
on the boy?
e What would be the difference to your answer to
part c if the elevator had an acceleration of 1.0 m s–2
downwards?
a. i use w=mg
b.i don't understand y the answer remains the same shouldn't it be ma=mg-N, where mg=650 and ma=65?
c,d,e.i don't get these questions
for part (a) yeah m g=w and for part (b) since there is no acceleration in the problem then mg=N. for (c) now there is an acceleration so draw a free body diagram of the forces acting on the boy? what direction is the acceleration and how does this effect the boy? this will answer (c) and (d) and (e)
From your own experience on an elevator, you notice that when the elevator is static, you feel... normal.
When it starts moving up, you feel heavier. After a while you feel normal again. When it's about to stop you feel lighter.
When it starts moving down, you feel lighter. After a while you feel normal again. When it's about to stop you feel heavier.
It is asking you about these concepts. If you feel heavier, indeed you must be "heavier". That is, if you were standing on a scale on the elevator, it would read a weight higher than your usual.
Weight is caused by the reactionary force from whatever it is you are standing on, in this case, the floor of the elevator. While standing, there are two forces acting on you to produce a net force: gravity (pulling downwards) and the floor (pushing upwards). If the elevator is still, acceleration is zero, so what does this say?
Fnet = ma (a = 0)
Fnet = 0
As we discussed, Fnet consists of two forces, gravity and the floor, so:
Fnet = 0
Fnet = Fgrav + Ffloor = 0
Fnet = mg + Ffloor = 0
Can you take it from here?
thank you...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
